USB DIY Slim Connector Shell - MicroB Plug
PRODUCT ID: 1826
DESCRIPTION
Make your own USB connections without slicing apart a USB cable and soldering
those thin wires inside. This is the 'slim' version of the DIY MicroB Male connector.
It's a little more elegant because instead of snapping two pieces together the
connector press-fits into the overmolding for a modern look. We also carry the slim
size in USB-A male and USB-microB female.
Normal DIY "USB shells" are available in USB A plug, micro B, mini B and USB A
socket.
Each shell comes with a plastic shell and a proper connector with easy-to-solder
tabs. All 5 pins are brought out, 3 on one side of the connector, two on the other.
http://www.adafruit.com/products/1826
10/5/2015
Technical Details
Assembled Dimensions: 26mm x 10mm x 7mm / 1" x 0.4" x 0.3"
Assembled Weight: 1.22g
Micro USB Connector Dimensions: 14mm x 8.5mm x 6mm / 0.6" x 0.3" x 0.2"
Micro USB Connector Weight: 0.6g
很抱歉,暂时无法提供与“1826”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+8.378061+1.08596
