USB-B-S-X-X-TH-X-XX
REVISION M
DO NOT
SCALE FROM
THIS PRINT
OPTIONS
-TR: TAPE & REEL
(LEAVE BLANK FOR TRAY PACKAGING)
E&I OPTION
-R: RoHS COMPLIANT
TYPE
-B
CONFIGURATION
-S: SINGLE
C5
COLOR
PLATING SPECIFICATION
-B: BLACK
-W: WHITE
-F: GOLD FLASH ON MATING AREA
MATTE TIN ON TAILS (100U" MIN)
WITH NICKEL UNDERPLATE
(SEE NOTE 2 FOR -R OPTION)
-S: SELECTIVE, .000030 GOLD ON MATING AREA
M
5.60±0.10 .220±.004
8.45±0.10 .333±.004
TERMINATION
-TH: THRU HOLE
C7
M
16.20 .638
12.10 .476
M
0.80±0.10 .031±.004
C8
3.18±0.05 .125±.002
M
7.78±0.10 .306±.004
M
POS 3
CL
POS 4
RECOMMENDED PCB LAYOUT
POS 4
C1
3.10±0.20 .122±.008
M
14.80±0.25 .583±.010
C9
C3
0.25 .010
10.40 .409
0.62 .024
2.50±0.10 .098±.004
M
M
2.00±0.10 .079±.004
C2
2.71 .107
M
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MM[IN].
TOLERANCES ARE:
DECIMALS
ANGLES
.X: .3 [.01]
2
.XX: .13 [.005]
.XXX: .051 [.0020]
1. C REPRESENTS A CRITICAL DIMENSION.
2. ALL PARTS ARE RoHS COMPLIANT WITH OR WITHOUT -R.
2.00 .079
POS 3
10.80 .425
M
3.64 .143
NOTES:
POS 1
2.71 .107
M
C6
M
0.80±0.08 .031±.003
2.50 .098
POS 2
2.30 .091 (TYP)
2 PLCS
POS 1
POS 2
12.04 .474
0.92 .036 (TYP)
4 PLCS
MATERIAL:
C4
C10
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: PBT,
CONTACT: PHOSPHOR BRONZE
SHELL: STEEL; NICKEL PLATED
F:\DWG\MISC\MKTG\USB-B-S-X-X-TH-X-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
USB TYPE B RIGHT ANGLE THRU HOLE
DWG. NO.
BY:
USB-B-S-X-X-TH-X-XX
B.HARPENAU
2/06/06 SHEET 1 OF 1
很抱歉,暂时无法提供与“USB-B-S-F-B-TH”相匹配的价格&库存,您可以联系我们找货
