690-024-260-900
690-024-260-900
    USBTYPEC3.1MALEPLUGGOLDFL
690-024-260-900 数据手册
2. 5 0 TOLERANCE UNLESS OTHERWISE SPECIFIED IN MM: 0.0 ± 0.38 ANGLE ±3° 0.00 ± 0.25 0.000 ± 0.13 5 4.50 4.30 A1 2 SEPT.15/2015 DIMS UPDATE C.B OCT.11/2016 3 PLATING OPTIONS UPDATE C.B APR.12/2017 4 3.80 0.90 16.33 6.00 1 11.53 5.00 OD 4 3 8.28 0 8 7.44 6.4 5.4 6.65 0 R2.2 0 R2.2 1.20 44° 44° 4.50 OD 2 8.25 B1 A1 24.08 NOTES: 1. SPECIFICATIONS 1.1 Voltage: 1.2 Current Rating: 1.30 B12 8.55 2.40 6.83 A12 4.40 8.08 4.68 0.80 8.25 1.57 1.30 2.64 9.52 1 B1 8.60 13.50 ORIGINAL REDRAWN R.STA.MONICA A12 B12 11.71 16.00 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. 30 V AC (RMS) 3.0A for Vbus and corresponding GND 0.25A for all other contacts 1.3 Contact Resistance: 30 Milliohms Max. for Vbus and GND 50 Milliohms Max. for all other contacts 1.4 Insulation Resistance: 100 Megohms Min. 1.5 Dielectric Withstanding Voltage: 100V AC/Minute 1.6 Total Mating Force: 5N~20N at 12.5mm/sec. Max. 1.7 Total Unmating Force: 8N~20N at 12.5mm/sec. Max. 1.8 Operating Temperature: -55°C to +85°C 2. MATERIAL: 2.1 Housing: Thermoplastic, UL 94V-0, Black Color 2.2 Shell: Stainless Steel all over Nickel Plating 2.3 Contact: Copper Alloy with Gold Plating on Contact Area , all over Nickel Plating 2.4 GND Latch: Stainless Steel all over Nickel Plating Tab with Lead Free Tin Alloy 2.5 Back Shell: Stainless Steel all over Nickel Plating 3. PART NUMBER: 690-024-260-900 for Gold flash plating 690-024-360-900 for 15µ” Gold ACAD REFERENCE NO.: 690-024-260-900 USB 3.1 TYPE C TO 2.0 PLUG CONNECTOR DRAWN: R.STA.MONICA DATE: SEPT.15/2015 CHECKED: DATE: PART NUMBER THIS SERIES FULLY CONFORMS TO THE EUROPEAN UNION DIRECTIVES COMPLIANT 2011/65/EU FOR RoHS COMPLIANCY. EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SEE DRAWING DRAWING NUMBER 690-024-260-900 SHEET 1 OF 1 ISSUE 4
690-024-260-900 价格&库存
很抱歉,暂时无法提供与“690-024-260-900”相匹配的价格&库存,您可以联系我们找货
