USBR-A-S-F-O-TH
USBR-A-S-F-O-TH
    SAMTEC(申泰)
    弯插
    USB连接器 Type-A 4P 弯插 端口数:1 额定电压:30VAC 工作温度:-50℃~+85℃
USBR-A-S-F-O-TH 数据手册
STANDARD & RUGGED USB 2.0 USB-A/USBR-A/USB-AM SERIES SPECIFICATIONS Insulator Material: High Temperature Thermoplastic Contact Material: Phosphor Bronze Plating: Gold on Contacts, Nickel on Shell, Tin on Tails Operating Temp Range: -50 °C to +85 °C Voltage Rating: 30 VAC Cycles: 1500 (max tested) Packaging: Packaged and shipped in Bulk Packaging Trays; Trays suitable for automation available Lead–Free Solderable: –TH & –VU=Yes (Wave Solder only) TID Numbers (USB-A): USB-A-D-X-X-TH (61001199) USB-A-S-X-X-TH (61001180) USB-A-S-X-X-SM2 (61001152) TID Number (USB-AM): USB-AM-S-X-X-SM (61001154) - SERIES A - - SHELL TYPE USB –S = Standard Connector USBR COLOR –F = Single = Double (–TH option only) - –B = Gold Flash on Mating Area, Tin on Tails –D = Increased Retention Connector (Complies with Class 1, DIV II minimum withdrawal requirement of 15N.) - PLATING –TH = Black (USB only) = Through-hole –SM2 –W –S = Surface Mount (USB only) = White (USB only) = 30 µ" (0.76 µm) Gold on Mating Area, Tin on Tails TERMINATION –VU –O = Upright, Through-hole = Orange (USBR only) (12.50) .492 (16.40) .646 (5.72) .225 (5.12) .202 (6.90) .272 —SM2 (6.90) .272 —TH (12.50) .492 (19.20) .756 (5.12) .202 (14.40) .567 (13.62) .536 (14.50) .571 (15.49) .610 (5.12) .202 (7.10) .280 USB - —VU TYPE –AM = A Type (Plug) —D (Requires —TH) - SHELL TYPE –S = Single - PLATING - COLOR –F –B = Gold Flash on Mating Area, Tin on Tails = Black –W = White –S - TERMINATION –TH = Through-hole –SM1 = Surface Mount = 30 µ" (0.76 µm) Gold on Mating Area, Tin on Tails (18.80) .740 (18.70) .736 (4.52) .178 (4.50) .177 (14.70) .579 (14.60) .575 (12.00) .472 (12.00) .472 (12.00) .472 —SM1 (12.50) .492 —TH samtec.com?USB-A, samtec.com?USBR-A or samtec.com?USB-AM Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
USBR-A-S-F-O-TH
1. 物料型号:文档列出了不同型号的USB连接器,包括USB-A、USBR-A和USB-AM,每种型号都有不同的后缀以区分其特性,例如-TH表示通孔型,-SM2表示表面贴装型。
2. 器件简介:USB 2.0系列连接器符合标准和坚固的USB 2.0规范,适用于多种安装方式和颜色选项。
3. 引脚分配:文档中提供了详细的引脚分配图,但未提供具体的引脚功能描述。
4. 参数特性:包括绝缘材料、接触材料、颜色选项、端接类型、镀层类型、操作温度范围、电压等级等。
5. 功能详解:文档提到了增加的保持力连接器,符合Class 1, DIV II的最小拔出力要求,以及1500次的最大测试循环次数。
6. 应用信息:连接器设计用于多种应用,包括自动化包装托盘,适用于自动化。
7. 封装信息:提供了TID编号,用于识别不同的USB连接器型号。
8. 其他信息:文档还提到了无铅可焊性,以及Samtec公司保留未经通知更改其规格的权利。
USBR-A-S-F-O-TH 价格&库存
很抱歉,暂时无法提供与“USBR-A-S-F-O-TH”相匹配的价格&库存,您可以联系我们找货
USBR-A-S-F-O-TH
  • 1+19.35182
  • 10+16.36184
  • 100+13.35999
  • 500+8.38856
库存:1074
