Additional Resources:
Product Page
date
08/05/2022
page 1 of 3
SERIES: UJ2-AV-TH | DESCRIPTION: USB RECEPTACLE
FEATURES
• USB type A jack
• USB 2.0
• vertical orientation
• through hole mounting
PART NUMBER KEY
UJ2-AV - X X - TH
Base Number
Insulator Color:
“blank” = black
W1 = white
Contact Plating
Thickness (gold):
1 = 3 µ”
2 = 6 µ”
4 = 30 µ”
Packaging Style:
TH = through hole
Notes:
1. White insulator option only
available with 30 µ” plating
SPECIFICATIONS
parameter
conditions/description
USB standard
USB 2.0
min
typ
rated input voltage
rated input current
contact resistance1
between terminals and mating plug
insulation resistance
voltage withstand
units
30
Vac
1.0
A
30
mΩ
500
Vac
35
N
1000
MΩ
for 1 minute
insertion force
withdrawal force
10
operating temperature
N
-20
life
85
1,500
flammability rating
UL94V-0
RoHS
yes
Note:
max
°C
cycles
1. When measured at 20 mV / 100 mA.
2. All specifications measured at 15~35°C, humidity at 25~85%, under atmospheric pressure of 86~106 kPa, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
dipped in solder pot for 5 ±0.5 seconds
min
cuidevices.com
typ
240
max
units
°C
Product Page
CUI DEVICES | SERIES: UJ2-AV-TH | DESCRIPTION: USB RECEPTACLE
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm
tolerance:
X.X ±0.38 mm
X.XX ±0.25 mm
MATERIAL
PLATING
contact terminals
phosphor bronze
contact: gold over nickel
solder: tin over nickel
shield
steel
nickel
insulator
PBT
Recommended PCB Layout
Top View
cuidevices.com
Product Page
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
08/05/2016
1.01
brand update
02/05/2020
1.02
added USB standard
04/20/2022
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“UJ2-AV-W4-TH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+2.89357
- 25+2.53603
- 40+2.51068
- 80+2.43899
