USB-B-S-F-B-TH-R
USB-B-S-F-B-TH-R
    SAMTEC(申泰)
    USB-B-S-F-B-TH-R
USB-B-S-F-B-TH-R 数据手册
USB-B-S-X-X-TH-X-XX REVISION M DO NOT SCALE FROM THIS PRINT OPTIONS -TR: TAPE & REEL (LEAVE BLANK FOR TRAY PACKAGING) E&I OPTION -R: RoHS COMPLIANT TYPE -B CONFIGURATION -S: SINGLE C5 COLOR PLATING SPECIFICATION -B: BLACK -W: WHITE -F: GOLD FLASH ON MATING AREA MATTE TIN ON TAILS (100U" MIN) WITH NICKEL UNDERPLATE (SEE NOTE 2 FOR -R OPTION) -S: SELECTIVE, .000030 GOLD ON MATING AREA MATTE TIN ON TAILS (100U" MIN) WITH NICKEL UNDERPLATE (SEE NOTE 2 FOR -R OPTION) M 5.60±0.10 .220±.004 8.45±0.10 .333±.004 TERMINATION -TH: THRU HOLE C7 M 16.20 .638 12.10 .476 M 0.80±0.10 .031±.004 C8 3.18±0.05 .125±.002 M 7.78±0.10 .306±.004 M POS 3 CL POS 4 RECOMMENDED PCB LAYOUT POS 4 C1 3.10±0.20 .122±.008 M 14.80±0.25 .583±.010 C9 C3 0.25 .010 10.40 .409 0.62 .024 2.50±0.10 .098±.004 M M 2.00±0.10 .079±.004 C2 2.71 .107 M UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MM[IN]. TOLERANCES ARE: DECIMALS ANGLES .X: .3 [.01] 2 .XX: .13 [.005] .XXX: .051 [.0020] 1. C REPRESENTS A CRITICAL DIMENSION. 2. ALL PARTS ARE RoHS COMPLIANT WITH OR WITHOUT -R. 2.00 .079 POS 3 10.80 .425 M 3.64 .143 NOTES: POS 1 2.71 .107 M C6 M 0.80±0.08 .031±.003 2.50 .098 POS 2 2.30 .091 (TYP) 2 PLCS POS 1 POS 2 12.04 .474 0.92 .036 (TYP) 4 PLCS MATERIAL: C4 C10 PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: PBT, CONTACT: PHOSPHOR BRONZE SHELL: STEEL; NICKEL PLATED F:\DWG\MISC\MKTG\USB-B-S-X-X-TH-X-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: USB TYPE B RIGHT ANGLE THRU HOLE DWG. NO. BY: USB-B-S-X-X-TH-X-XX B.HARPENAU 2/06/06 SHEET 1 OF 1
USB-B-S-F-B-TH-R 价格&库存
很抱歉,暂时无法提供与“USB-B-S-F-B-TH-R”相匹配的价格&库存,您可以联系我们找货
