MUSBS-05-S-B-TH-TR
MUSBS-05-S-B-TH-TR
    SAMTEC(申泰)
    插件
    USB连接器 Mini-B 5P 直插 端口数:1 额定电流:3.1A 额定电压:30V 工作温度:-50℃~+85℃
MUSBS-05-S-B-TH-TR 数据手册
REVISION H NOTES: MUSBS-05-S-B-TH-XX-TR DESIGNED & DIMENSIONED 1. C REPRESENTS A CRITICAL DIMENSION. IN MILLIMETERS[INCHES] 2. MINIMUM PUSH OUT FORCE: 1N [.25 LB] 3. MAXIMUM HEIGHT VARIATION BETWEEN ANY TWO POSTS: 0.13[.005]. 4. MAXIMUM ALLOWABLE BOW: 0.05[.002] MM/MM AFTER ASSEMBLY. 5. PARTS TO BE PACKAGED IN TAPE AND REEL. 6. OR-104-01 TO BE COMPRESSED 20-40% TO MEET CEI/IEC 60529 CODE IP67. 7. FOR QUANTITIES UP TO 49 PIECES, NO LEADER, TRAILER, OR REEL WILL BE SUPPLIED. C FOR QUANTITIES 50-124, NO LEADER OR TRAILER WILL BE SUPPLIED. 8. EPOXY-01 MUST BE FLUSH OR BELOW FORMED BY THIS SURFACE. 10.54 .415 9. INSPECT 100% USING GO/NOGO GAUGE, REFER TO PTL. PACKAGING -TR: TAPE & REEL No OF POSITIONS -05 OPTION *-PF: PANEL FLANGE (LEAVE BLANK FOR NO MOUNTING HARDWARE) TERMINATION -TH: THROUGH HOLE PLATING SPECIFICATION -S: SELECTIVE, .000030 GOLD ON POST, TIN ON TAIL,WITH .000050 MIN NICKEL UNDERPLATING OVERALL. TYPE -B 8.38 .330 6.81 .268 REF * NOT TOOLED SH25-T OR-104-01 7.50 .295 REF C 1.60 .063 REF +0.10 5.50 0.00 R0.70 .028 REF 3.200 .1260 C-260-01-S 3.40 .134 0.30 .012 CL MUSBF-B-01 CL 2.65 .104 3.70 .146 REF 11.50 .453 REF C 1.57 .062 REF "A" 6.47 .255 REF CL 5.00 .197 +.004 .217 - .000 PIN 5 PIN 1 7.70 .303 REF 1.600 .0630 2.79 .110 (TYP) "A" CL C FIG 1 1.000 .0394 (SEE NOTE 9) 3.00 .118 SEE NOTE 8 EPOXY-01 SECTION "A"-"A" (MUSBS-05-S-B-TH SHOWN) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES X.X: 0.3 [.01] 2 X.XX: 0.13 [.005] X.XXX: 0.051 [.0020] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 4:1 INSULATOR: LCP UL 94V-0 COLOR: BLACK CONTACT: PHOS BRONZE OVERMOLD: E130i, COLOR: BLACK MAX REGRIND: 50% EPOXY-01 VOLUME: 0.02mL [.00 000 528 gal] MUSBS OVERMOLD SHOT WEIGHT: 4.90g [0.0108 lb] F:\DWG\MISC\MKTG\MUSBS-05-S-B-TH-XX-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MUSB TYPE B, VERTICAL SEALED DWG. NO. MUSBS-05-S-B-TH-XX-TR BY: T NEWTON 11/19/2008 SHEET 1 OF 4 REVISION H C IN-PROCESS 1 4.33 .171 (FILL C-260-01-X) 6.30 .248 1.000 .0394 REF 0.30 .012 C C 0.800 .0315 (TYP) 3.200 .1260 5.000 .1969 "C" 6.13 .242 REF 11.50 .453 7.70 .303 SECTION "B"-"B" C 3.400 .1339 C 12.17 .479 REF C 2.85 .112 C C "B" 4.60 .181 REF "B" C C-260-01-S MUSBF-B-01 IN-PROCESS 2 "C" (ADD OVERMOLD) 6.65 .262 5.62 .221 3.000 .1181 4.600 .181 C C 2.80±0.20 .110±0.000 C C 'H' C 0.660 .0260 (TYP) CL 0.305 .0120 (TYP) 1.000 .039 REF CL 0.30 .012 C 0.33 .013 2.16 .085 5.04 .198 0.64 .025 0.37 .015 0.35 .014 C 1.78 .070 DETAIL 'H' SCALE 15 : 1 * PROPRIETARY NOTE DO NOT SCALE DRAWING SHEET SCALE: 5:1 SECTION "C"-"C" F:\DWG\MISC\MKTG\MUSBS-05-S-B-TH-XX-TR-MKT.SLDDRW * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MUSB TYPE B, VERTICAL SEALED DWG. NO. MUSBS-05-S-B-TH-XX-TR BY: T NEWTON 11/19/2008 SHEET 2 OF 4 REVISION H IN-PROCESS 3 "D" (ADD SH25-T) 13.33 .525 REF 2.79 .110 REF SH25-T 1.000 .0394 REF "D" SECTION "D"-"D" IN-PROCESS 4 "G" (ADD EPOXY-01) EPOXY-01 "G" SECTION "G"-"G" * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 5:1 F:\DWG\MISC\MKTG\MUSBS-05-S-B-TH-XX-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MUSB TYPE B, VERTICAL SEALED DWG. NO. MUSBS-05-S-B-TH-XX-TR BY: T NEWTON 11/19/2008 SHEET 3 OF 4 REVISION H PACKAGING VIEW 32.00 1.260 REF 24.00 .945 REF USER DIRECTION OF UN-REELING POCKET NOT DETAILED * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1:1 F:\DWG\MISC\MKTG\MUSBS-05-S-B-TH-XX-TR-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: MUSB TYPE B, VERTICAL SEALED DWG. NO. MUSBS-05-S-B-TH-XX-TR BY: T NEWTON 11/19/2008 SHEET 4 OF 4
MUSBS-05-S-B-TH-TR 价格&库存
很抱歉,暂时无法提供与“MUSBS-05-S-B-TH-TR”相匹配的价格&库存,您可以联系我们找货
MUSBS-05-S-B-TH-TR
  • 175+36.45993175+4.73869
  • 525+32.62262525+4.23996
库存:1342
MUSBS-05-S-B-TH-TR
    • 1+33.83640
    • 10+32.95080
    • 30+32.35680
    库存:14
    MUSBS-05-S-B-TH-TR
    • 1+59.041821+7.67366
    • 10+50.1663410+6.52011
    • 25+47.0208525+6.11130
    • 50+44.7735950+5.81922
    库存:1342
