ZX62-B-5PA(11)
ZX62-B-5PA(11)
    HRS(广濑)
    CONN RCPT MICRO USB B SMD R/A
ZX62-B-5PA(11) 数据手册
Micro-USB connectors meeting USB 2.0 Standard Note: Contact us to ascertain whether a TID number has been acquired for an individual product. Fig.1 ■Overview Extremely small highly reliable connectors complying with physical, electrical and environmental requirements of Micro-USB standard (USB 2.0). Receptacles and plugs are available in a wide variety of mounting and termination styles, allowing their use in various applications. Reverse (Top mount) Drop-in (Mid-mount) Standard (Bottom mount) ■Features 1. Size reduction Compared with the standard Mini-USB connectors, the size of ZX connectors is reduced by approximately 60% while still allowing a high-speed data transfer of 480 Mbps, specified in USB 2.0. 2. Receptacle styles Two interface configurations: Micro-B and Micro-AB in standard, mid-mount and reverse mounting styles. SMT and through-hole (shell) PC board terminations. Fig.2 3. Plug styles Corresponding to the receptacle styles, two interface configurations: Micro-A and Micro-B, with direct wire or PCB wire soldering. Several plug styles can be used for data transmission, earphone or charging applications. USB 2.0 Hi-Speed (480 Mbps) Eye diagram measurement results: Measured with 2.4 m long USB 2.0 cable 4. Smooth mating and unmating A smooth mating and unmating operation results in less wear and a longer product life. The unique Hirose active latch mechanism produces a reliable and durable connector. Even after repeated use, the user will experience a smooth click sensation when mating the connectors. Note: The statement above only applies when using both plug and receptacles made by Hirose Electric. 200 mV/div Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ZX Series TP2 500ps/div Fig.3 5. Hirose was the first company to obtain a Micro-USB certification (TID number). 2014.8w 1 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Specifications Ratings Current rating 1 A (per contact) or Voltage rating 30 V AC 1.8 A (contacts No. 1 and 5) and Operating temperature range -30°C to +85 °C (Note1) 0.5 A (contacts No. 2, 3, and 4) Storage temperature range -30 °C to +60°C Item Specification Conditions 1. Contact resistance 30 mø max. 100 mA 2. Withstanding voltage No flashover or insulation breakdown 100 V AC / 1 minute 3. Capacitance 2 pF max. Between adjacent contacts at 1,000 Hz (AC voltage) 4. Durability Contact resistance: Rise from initial value of 10 mø max. 10,000 cycles 5. Total insertion/removal force Insertion force: 35 N max., Removal force: 8 N min. Mated with corresponding connector Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note1: Includes temperature rise caused by current flow. Note2: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials ●Receptacles Part Material Finish Remarks Insulator LCP Micro-B: Black, Micro-AB: Gray UL94V-0 Contacts Copper alloy Selective gold plated --------------- Shell Stainless steel Tin alloy plating --------------- ●Plugs Part Material Finish Remarks Insulator LCP Micro-B: Black, Micro-AB: Gray UL94V-0 Contacts Copper alloy Selective gold plated --------------- Shell Stainless steel Tin alloy plating --------------- ■Ordering information ●Receptacles ZX 62 RD - B - 5 P * 8 q w e t r y u i ●Plugs ZX 40 - B - 5 S * - UNIT q w r t y u o ZX 40 - B - SLDA q Interface Micro-A Micro-B Micro-AB 2 w r Receptacle o Plug qSeries name wTermination style eBoard mounting style (Receptacles) ZX 10's: Right-angle PCB wire, SMT 20's: Straight, PCB wire 40's: Direct wire 60's: Right-angle, PCB wire 80's: Cradle SMT Standard (Bottom mount) Standard (Bottom mount) through hole Reverse (Top mount) Reverse (Top mount) through hole Drop-in (Mid-mount) Micro-A Micro-B Micro-AB 5 Receptacle- Male Plug – Female Blank D R RD M rMating side configuration A B AB tNumber of contacts yContact type P S uSerial No. iShell termination style – Blank SMT Receptacles 8 Through hole (solder tab length: 0.8mm) oComponents-plugs UNIT Assembly (Insulator/contact/lock) Cover (Note 1) Note 1: Classifiers such as A, B, and C are entered for *. ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Configurations Mating side configuration Type Part No. 3D Image Page SMT ZX62-B-5PA(11) 4 SMT + DIP ZX62D-B-5PA8 4 Reverse SMT ZX62R-B-5P 5 Drop-in SMT ZX62M-B-5P(01) 5 SMT ZX62-AB-5PA(11) 6 SMT + DIP ZX62D-AB-5P8 6 SMT ZX62R-AB-5P 7 SMT + DIP ZX62RD-AB-5P8 7 Direct wire soldering Assembly :ZX40-B-5S-UNIT(12) (insulator/contacts/lock) Cover-top :ZX40-B-SLDA Cover-bottom :ZX40-SLDB 9 and 10 PCB wire soldering (straight, through hole) Assembly :ZX20-B-5S-UNIT (insulator/contacts/lock) Cover :ZX20-B-SLDC PCB wire soldering (SMT) Assembly :ZX64-B-5S-UNIT(14) (insulator/contacts/lock) Cover-top :ZX64-B-SLDA Cover- bottom :ZX64-SLDB 12 and 13 PCB wire soldering (SMT) Assembly :ZX64-B-5S-UNIT(14) (insulator/contacts/lock) Cover :ZX64-B-SLDC 12 and 14 Assembly :ZX40-A-5S-UNIT (insulator/contacts/lock) Cover-top :ZX40-A-SLDA Cover- bottom :ZX40-SLDB 15 and 16 Standard R e c e p t a c l e s Standard Micro-AB P l u g s Reverse Cradles Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Micro-B Micro-B Micro-A Direct wire soldering Micro-B SMT + DIP 11 ZX80-B-5S With lock 17 ZX80-B-5SA Without lock 17 Note: 1. Part numbers in the Plugs section of the above table list the Assembly (insulator/contacts/locks) and the corresponding Shields/Covers. Note: 2. Optional Printed Circuit boards for the Plugs are shown for reference only. Not supplied with applicable connectors. Note: 3. The color of the insulators body in the Assembly (insulator/contacts/lock) shown in the 3D Image column above is blue for clarity. Refer to the Materials (Page 2) for correct colors. 3 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Receptacles Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Micro B - Standard (Bottom mount), Shell SMT Part No. HRS No. Packaging ZX62-B-5PA(11) 242-0033-8 11 3,500 pcs/reel BRecommended PCB mounting pattern 8.3 4.1 2.6 0.6 7.5 4.3 6.2 9.8 2.5 1.45 0.5 5 2.8 1.6 3.35 1.35 1.9 No.5 1.3 0.4 No.1 NO CONDUCTIVE TRACES PCB EDGE No.1 7.9 No.5 2.15 All dimensions: mm ●Micro B - Standard (Bottom mount), Shell through hole Part No. HRS No. Packaging ZX62D-B-5PA8 242-0056-3 2,000 pcs/reel BRecommended PCB mounting pattern 4.85 2.6 0.65 0.4 D) No.1 1.05(LAND) 0.65(TH) No.5 1.35 AN 7.5 4.1 5.2 7.2 9.4 PCB EDGE 5 2.5 0.5 1.3 R0.325(TH) 0.5(TH) 0.6 2.75 NO CONDUCTIVE TRACES (TH) .3 R0 1.5(TH) 1.9 2.9 R0.5(LAND) R0.325(TH) No.1 4.85 7.2 0.8 5(L 3.35 .52 0.2 0.1 1.25(LAND) 0.85(TH) R0 2.15 2.9 No.5 All dimensions: mm 4 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Receptacles Part No. HRS No. Packaging ZX62R-B-5P 242-0028-8 2,000 pcs/reel BRecommended PCB8.3 mounting pattern 4.1 2.6 1.3 No.1 No.5 1.35 0.5 2.9 3.9 5.6 6.6 9.8 0.6 No.1 5 2.5 1.45 1.9 2 3.35 0.4 0.43 No.5 NO CONDUCTIVE TRACES 2.15 7.5 8.8 All dimensions: mm ●Micro B - Drop-in (Mid-mount), Shell SMT Part No. ZX62M-B-5P(01) HRS No. Packaging 242-0024-7 01 1,500 pcs/reel BRecommended PCB mounting pattern 2.74 4.3 5 5.3 2.4 4.8 1.9 3.6 1.05 0.6 0.4 1.3 2.6 6.9 7.8 8.8 12 PCB EDGE 1.25 2.4 1.4 No.5 3 1.5 4.3 0. 7.15 1.9 7.5 C .4 R0 No.1 4.7 2 1.23 11.5 7.5 5.15 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Micro B - Reverse (Top mount) Shell SMT No.5 No.1 0.25 1.3 2.6 4.7 All dimensions: mm 5 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Receptacles Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Micro AB - Standard (Bottom mount), Shell SMT Part No. HRS No. Packaging ZX62-AB-5PA(11) 242-0045-7 11 3,500 pcs/reel 8.3 4.1 2.6 1.3 No.1 No.5 3.35 1.6 0.4 1.35 BRecommended PCB mounting pattern 0.6 5 2.5 2.8 1.9 0.5 4.3 6.2 9.8 1.45 7.5 PCB EDGE NO CONDUCTIVE TRACES No.1 No.5 8.8 2.15 ●Micro AB - Standard (Bottom mount), Shell through hole All dimensions: mm Part No. HRS No. Packaging ZX62D-AB-5P8 242-0027-5 2,000 pcs/reel 0.4 No.1 1.05(LAND) 0.65(TH) NO CONDUCTIVE TRACES No.5 1.35 1.5 1.7 (0.325) (0.5) 6 0.5 4.1 5.2 7.35(TH) 9(TH) 9.4 0.6 5 2.025 3.125 2.5 1.3 1.5(TH) 1.9 R0.5(LAND) PCB EDGE 7.5 2.625 R0.25(TH) 2.8 R0.3(TH) No.1 4.45 8.35 0.6 0.85(TH) R0.45(LAND) 4.45 2.6 1.3 3.475 3.125 1.25(LAND) BRecommended PCB mounting pattern No.5 All dimensions: mm ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Receptacles Part No. HRS No. Packaging ZX62R-AB-5P 242-0035-3 2,000 pcs/reel BRecommended PCB mounting pattern 8.3 4.1 2.6 1.3 No.5 NO CONDUCTIVE TRACES No.1 1.45 0.43 0.5 2.9 0.85 4.75 6.6 9.8 7.5 0.6 5 2.5 1.9 3.35 1.6 1.35 0.4 PCB EDGE No.5 .4 R0 4- 8.8 No.1 ●Micro AB - Reverse (Top mount), Shell through hole 2.15 All dimensions: mm Part No. HRS No. Packaging ZX62RD-AB-5P8 242-0025-0 2,000 pcs/reel BRecommended PCB mounting pattern R0.45(LAND) No.1 R0.2MAX 1.05(LAND) 0.65(TH) 1.35 1.5 1.7 0.4 NO CONDUCTIVE TRACES 3.475 7.5 No.1 0.6 5 2.5 No.5 R0 .5( LA ND ) 4.45 8.35 0.6 1.9 4.75 0.85 1.5(TH) 2.9 1.3 (TH) (0.325) R0.3 (0.5) 2.625 No.5 1.25(LAND) 0.85(TH) R0.25(TH) 9.4 9(TH) 7.35(TH) 6.6 4.45 2.6 1.3 3.125 0.555 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Micro AB - Reverse (Top mount), Shell SMT 2.025 3.125 All dimensions: mm PCB EDGE 7 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard Plugs – assembled (not-terminated, without overmold) Components ZX40 - Direct wire soldering ZX40-*-SLDA Cover-top ZX40-*-5S-UNIT Assembly (insulator/ contacts/lock) *No PCB required Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ZX40-SLDB Cover-bottom ZX20 - PCB wire soldering ZX20-*-SLDC Cover ZX20-*-5S-UNIT Assembly (insulator/contacts/lock) *Vertical through hole PCB termination ZX64 - PCB wire soldering ZX64-*-SLDA Cover-top ZX64-*-5S-UNIT Assembly (insulator/ contacts/lock) *Right angle through hole PCB termination ZX64-SLDB Cover-bottom 8 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs ●Micro B - Assembly (insulator/contacts/lock) – Direct wire soldering Part No. HRS No. Packaging ZX40-B-5S-UNIT(12) 242-0002-4 12 4,000 pcs/reel 14.1 7.9 No.5 No.1 4.2 All dimensions: mm ●Micro B - Component, Cover-top - Direct wire soldering HRS No. Packaging ZX40-B-SLDA 242-0003-7 4,000 pcs/reel 22.6 Part No. 6.85 8 1.8 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact HRS for Cable Termination Procedure Manual. All dimensions: mm 9 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs 16.2 16.2 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Micro A, Micro B - Component, Cover-bottom - Direct wire soldering 8 8 All dimensions: mm ZX40-SLDB(3.3) ZX40-SLDB Part No. HRS No. ZX40-SLDB 242-0004-0 ZX40-SLDB(3.3) 242-0023-4 Packaging Cable dia. Ø3.8 4,000 pcs/reel Ø3.3 22.6 ●Assembled 6.85 1.8 4.75 8.6 All dimensions: mm 10 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs ●Micro B - Assembly (insulator/contacts/lock) - Vertical through hole PCB wire soldering (non-direct) Part No. HRS No. Packaging ZX20-B-5S-UNIT 242-0012-8 00 4,000 pcs/pks Contact HRS for Cable Termination Procedure Manual. 1 1.4 PCB mounting pattern gh ho le) 12.2 *PCB required (not supplied) Max. thickness: 0.6mm (Th 0.7 No.5 1(Land) 10.25 R0 7.9 No.1 0.35 1.55 No.5 3.975 d) .3(T 8.2 1.6(Land) 1.55 e) hol hro (Lan ugh 1.3 2.6 R0.5 1.2(Through hole) 4.2 5-Ø ) nd 0.6(Through hole) La .1( No.1 rou Ø1 5- All dimensions: mm ●Micro B - Component, Cover - through hole HRS No. Packaging 242-0022-1 4,000 pcs/reel 12.1 8.2 2-0.2 1.1 Part No. ZX20-B-SLDC ●Assembled 8.2 2.6 1.3 2-0.2 1 1.4 5-0.15 6.85 6.85 Assembly (insulator/contacts/lock) 0.6 12.2 1.8 8 Cover 1.8 0.35 1.55 8.4 0.6 4.4 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.6 1.3 5-0.15 All dimensions: mm 11 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs ●Micro B - Assembly (insulator/contacts/lock) - Right angle SMT Part No. HRS No. Packaging ZX64-B-5S-UNIT(14) 242-0009-3 14 1 piece Contact HRS for Cable Termination Procedure Manual. 2.6 1.3 16.1 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5-0.15 PCB mounting pattern 1.5 6 *PCB required (not supplied) Max. thickness: 1.0mm 7.9 1.3 No.5 2.6 No.1 No.1 3.7 0.35 1.1 0.5 No.5 6.8 All dimensions: mm ●Micro B - Component, Cover-top – Right angle SMT HRS No. Packaging ZX64-B-SLDA 242-0013-0 4,000 pcs/reel 24.7 Part No. 6.85 1.8 8 All dimensions: mm 12 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs ●Micro B - Component, Cover-bottom - Right angle SMT HRS No. Packaging 242-0049-8 4,000 pcs/reel 24.7 ●Assembled 8 Assembly (insulator/contacts/lock) Cover-top 1.8 4.1 6.85 8.4 Cover-bottom All dimensions: mm ●Micro B - Component, Shell/cover – Right angle SMT Part No. HRS No. Packaging ZX64-B-SLDC 242-0018-4 4,000 pcs/reel 6.85 Shell/cover, without cable clamp This shell/cover does not require ZX64-SLDB. 8 16.1 16.1 1.8 ●Assembled 8.4 Assembly (insulator/contacts/lock) Cover-top 1.8 6.85 4.1 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 18.25 Part No. ZX64-SLDB Cover-bottom All dimensions: mm 13 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs ●Micro A - Assembly (insulator/contacts/lock) - Direct wire soldering Part No. HRS No. Packaging ZX40-A-5S-UNIT 242-0010-2 1 piece 12.4 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact HRS for Cable Termination Procedure Manual. Contacts 7.9 No.1 4.2 No.5 Insulator body (color grey) All dimensions: mm ●Micro A - Component, Cover-top - Direct wire soldering HRS No. Packaging 242-0011-5 4,000 pcs/reel 22.6 Part No. ZX40-A-SLDA 6.85 1.8 8 All dimensions: mm 14 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plugs 16.2 16.2 8 8 All dimensions: mm ZX40-SLDB Part No. HRS No. ZX40-SLDB 242-0004-0 ZX40-SLDB(3.3) 242-0023-4 ZX40-SLDB(3.3) Packaging 4,000 pcs/reel Cable dia. Ø3.8 Ø3.3 22.6 ●Assembled 6.85 Assembly (insulator/contacts/lock) Cover-top 1.8 8.6 4.75 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Micro A, Micro B - Component, Cover-bottom - Direct wire soldering Cover-bottom All dimensions: mm 15 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard ■Plug-Vertical, cradle mount, Shell through hole ●Micro B, with lock 6.65 2-0.2 2.6 1.3 5-0.15 No.1 HRS No. Packaging ZX80-B-5S 242-0017-1 100 pcs/pks 6 Part No. 0.7 R1. 3.52 2.32 0.37 3.15 No.5 1 1.86 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.78 2.42 1.88 6.85 8.55 2.5 7.1 16.55 20.55 13 1.15 All dimensions: mm ●Micro B, without lock 6.65 2-0.2 2.6 1.3 5-0.15 No.1 HRS No. Packaging ZX80-B-5SA 242-0019-7 100 pcs/pks BPCB mounting pattern Ø2 .2 (H ol 25 . R0 8- 2e) 13 0.5(Through hole) 1.1(Land) 2.6 6.65 16.55 Contact No.5 1.86 .55 0.4 1.3 2.2(Land) R0 1.6(Through hole) 2.9 2.2 8- Contact No.1 16 1.15 3.15 0.37 1.1(Land) 0.5(Through hole) 0.7 2.5 7.1 16.55 20.55 1.3(Through hole) 1.9(Land) Part No. 6 R1. 3.52 2.32 0.37 3.15 No.5 1 1.86 2.78 2.42 1.88 6.85 8.55 All dimensions: mm ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard BPackaging Specifications ●Embossed carrier tape dimensions Unreeling direction C D 0.5 Ø1 .5 E 2 3 Ø1 1.75 4 ●Reel Dimensions Unreeling direction Ø3 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A B 80 Part No. Part No. ZX62-B-5PA(11) ZX62-AB-5PA(11) ZX62M-B-5P(01) Other A dimension 24 24 24 16 B dimension 11.5 11.5 11.5 7.5 ZX62-B-5PA(11) ZX62-AB-5PA(11) ZX62M-B-5P(01) Other D dimension 30.4 30.4 30.4 22.4 E dimension 24.4 24.4 24.4 16.4 BRecommended Temperature Profile - Receptacles ●Using lead-free solder paste The temperature profile is based on the left conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/ thickness and board size/thickness. Contact your solder paste and equipment manufacturer for specific recommendations. (ç) 240ç 230çmin 250 200 180ç 150 150ç 100 50 60S 30S Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. BPrecautions 1. Exercise care when handling the connectors. Do not subject them to excessive external forces when mating/un-mating. 2. Mate and un-mate as intended, holding by the overmolded body, in the correct direction. Do not un-mate by pulling on the cable. 3. Some tooling marks may be visible on the surfaces of receptacle (shell/cover). No form/fit or function is affected. 4. Appearance of the surface finishes on the receptacles may vary between production runs. No affect on form, fit or function. 17 ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 18 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard 19 Apr.1.2016 Copyright 2016 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ZX Series●Micro-USB connectors meeting requirements of USB 2.0 Standard Powered by TCPDF (www.tcpdf.org) USA: HIROSE ELECTRIC (U.S.A.), INC. Headquarters 2688 Westhills Court, Simi Valley, CA 93065-6235 Phone : +1-805-522-7958 Fax : +1-805-522-3217 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. San Jose Office 3255 Scott Boulevard, Building 7, Suite 101 Santa Clara, CA 95054 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hiroseusa.com USA: HIROSE ELECTRIC (U.S.A.), INC. Detroit Office (Automotive) 37677 Professional Center Drive, Suite #100C Livonia, MI 48154 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hiroseusa.com THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hiroseeurope.com GERMANY: HIROSE ELECTRIC EUROPE B.V. German Branch Herzog-Carl-Strasse 4 D-73760 Ostfildern (Scharnhauser Park) Phone : +49-711-4560-02-1 Fax : +49-711-4560-02-299 http://www.hirose.de GERMANY: HIROSE ELECTRIC EUROPE B.V. Nuernberg Office Muggenhofer Str. 136 90429 Nuernberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.de UNITED KINGDOM: Hirose Electric Europe BV (UK Branch) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 CHINA: HIROSE ELECTRIC (SHANGHAI) CO., LTD. 1601, Henderson Metropolitan, NO.300, East Nanjing Road, Huangpu District, Shanghai, China 200001 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose-china.com.cn CHINA: HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD. Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose-china.com.cn HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose-hongkong.com.hk TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7350 http://www.hirose-taiwan.com.tw KOREA: SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD Delhi Liaison Office HIROSE KOREA CO., LTD. HIROSE ELECTRIC SINGAPORE PTE. LTD. 1261-10, Jeoungwhang-Dong, Shihung-City, 10 Anson Road #26-1, International Plaza Suite No. 606 5th Floor SB Tower 1A/1 Sector 16 A Filmcity Noida 201301 Uttar Pradesh-India Kyunggi-Do 429-450 079903, Singapore Phone : +91-120-4804917 Phone : +82-31-496-7000,7124 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +82-31-496-7100 Fax : +65-6324-6123 http://www.hirose-singapore.com.sg http://www.hirose.com/sg/ http://www.hirose.co.kr INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. Bangalore Liaison office Unit No.03, Ground Floor, Explorer Building International Tech Park Whitefield Road, Bangalore 560066 Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose-singapore.com.sg ® 20 MALAYSIA: HIROSE ELECTRIC SINGAPORE PTE. LTD (Representative office) 1-10-07, Suntech @ Penang Cybercity (1164),Lintang Mayang Pasir 3,11950, Bayan Baru, Penang, Malaysia. Phone : +604-619-2564 Fax : +604-619-2574 http://www.hirose.com/sg/ 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2014. Contents are subject to change without notice for the purpose of improvements.
ZX62-B-5PA(11)
物料型号: - 该文档描述了符合USB 2.0标准的Micro-USB连接器,型号包括ZX系列的不同变体,例如ZX62-B-5PA(11)、ZX62D-B-5PA8等。
器件简介: - 这些连接器非常小巧且高度可靠,符合Micro-USB标准的物理、电气和环境要求。它们支持高速数据传输,最高可达480 Mbps。
引脚分配: - 文档中提到了5个接触点的配置,具体分配未详细说明,但通常Micro-USB有5个引脚用于不同的信号和电源。
参数特性: - 电流额定值:每个接触点1A或1和5号接触点合计1.8A,2、3和4号接触点0.5A。 - 电压额定值:工作温度范围30V AC -30°C至+85°C。 - 接触电阻、耐电压、电容和耐久性等参数均有具体数值。
功能详解: - 连接器具有尺寸减小、多种接口配置、平滑的插拔操作等特点。Hirose公司是首家获得Micro-USB认证(TID编号)的公司。
应用信息: - 这些连接器可用于数据传输、耳机或充电应用。
封装信息: - 提供了多种安装和终止风格的插座和插头,包括SMT和直插式PCB终止。
ZX62-B-5PA(11) 价格&库存
很抱歉,暂时无法提供与“ZX62-B-5PA(11)”相匹配的价格&库存,您可以联系我们找货
