P136-000-UHD-V2
P136-000-UHD-V2
    TRIPPLITE
    P136-000-UHD-V2
P136-000-UHD-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to HDMI 4K Active Adapter Video Converter, DP ver 1.2, HDCP 1.3, DPCP 1.0 (M/F), 4K 30 Hz Highlights ● Active adapter for use with any Displayport port ● Connect a 4K HDMI monitor to a computer with a Displayport 1.2 output ● Displayport Male to HDMI Female ● HDCP 1.3 and DPCP 1.0 compliant MODEL NUMBER: P136-000-UHD-V2 Package Includes ● Description Tripp Lite's P136-000-UHD-V2 DisplayPort 1.2 to HDMI 4K Active Converter Adapter allows you to connect a computer with a Displayport output to a HDMI monitor. Supports computer video resolutions up to 4K x 2K @ 24/30 Hz (Ultra HD). It is an active adapter, converting both Single-Mode and Dual-Mode (DP++) DisplayPort output. It’s perfect for use with graphics cards, such as AMD Eyefinity, that do not output DP++ signals. Adapter is Plug-and-Play and requires no drivers or software. Backwards compatibile to previous Displayport versions (1.0, 1.1, 1.2). Fully molded ends ensure long life enjoyment. Features ● Supports DisplayPort 1.2a input and HDMI1.4b output ● Active adapter for use with any Displayport port, converts Single-Mode and Dual-Mode (DP++) DisplayPort output ● Perfect for use with graphics cards, such as AMD Eyefinity, that do not output DP++ signals ● Supports HDMI highest video resolution 4K x 2K @ 24/30 Hz ● Content protection of HDCP Rx and Tx keys to support HDCP repeater ● Supports up to 8 channel LPCM, compressed audio(AC-3,DTS) and HBR audio format ● Supports up to 192khz audio frame rate and up to 24-bit audio sample size ● Integrated both HDCP Rx and Tx keys to support HDCP repeater ● HDCP 1.3 and DPCP 1.0 compliant ● Powered from DisplayPort source ● Plug and Play Specifications OVERVIEW UPC Code 037332188328 1/2 P136-000-UHD-V2 DisplayPort 1.2 to HDMI 4K Active Converter Adapter 1000 Eaton Boulevard Cleveland, OH 44122 United States Technology HDMI; DisplayPort PHYSICAL Color Black Shipping Dimensions (hwd / in.) 5.90 x 3.90 x 0.50 Shipping Dimensions (hwd / cm) 14.99 x 9.91 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 HDMI (FEMALE) FEATURES & SPECIFICATIONS HDCP Specification 1.3 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P136-000-UHD-V2 价格&库存
很抱歉,暂时无法提供与“P136-000-UHD-V2”相匹配的价格&库存,您可以联系我们找货
