P136-000-1
P136-000-1
    TRIPPLITE
    P136-000-1
P136-000-1 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort to HDMI Adapter Video Converter (M/F) MODEL NUMBER: P136-000-1 Highlights ● Compact design - Displayport (Male) to HDMI (Female) ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● HDCP-compliant ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dualmode port System Requirements ● Computer with a Displayport output ● Display with an HDMI port ● The P136-000-1 supports transmission of an audio signal as long as it is supported by the Displayport source. Check the documentation for your Displayport source for compatibility. ● The P136-000-1 is a Passive adapter and requires that the connected computer has a DP++ ( Displayport ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your Displayport source for compatibility. Connect an HDMI monitor to a computer with a Displayport output. Description Tripp Lite's P136-000-1 Compact Displayport (Male) to HDMI (Female) Adapter allows you to connect a computer with a Displayport output to an HDMI monitor. Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p. Fully-molded design ensures a long life of enjoyment. The P136000-1 is a passive adapter and requires that the connected computer has a DP++ ( DisplayPort ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your Displayport source for compatibility. Features ● Connect a HDMI monitor to a computer with a Displayport output ● Displayport (Male) to HDMI (Female); fully-molded ● Supports computer video resolutions up to 1920 x 1200, and HD resolutions up to 1080p ● The P136-000-1 supports transmission of an audio signal as long as it is supported by the Displayport source. Check the documentation for your Displayport source for compatibility. ● Supports DTS-HD, Dolby True HD and 7.1 Channel Surround Sound Audio ● The P136-000-1 is a passive adapter and requires that the connected computer has a DP++ ( Displayport ++ ) port, which allows HDMI and DVI signals to be passed through; check the documentation for your Displayport source for compatibility. ● HDCP-compliant Specifications OVERVIEW UPC Code 037332184788 Technology HDMI; DisplayPort PHYSICAL 1/2 Package Includes ● Displayport Male to HDMI Female adapter 1000 Eaton Boulevard Cleveland, OH 44122 United States Color Black Shipping Dimensions (hwd / in.) 3.20 x 3.20 x 0.50 Shipping Dimensions (hwd / cm) 8.13 x 8.13 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 Unit Dimensions (hwd / cm) 9 x 18 x 55 Unit Weight (lbs.) .09 Unit Weight (kg) 0.04 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 HDMI (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P136-000-1 价格&库存
很抱歉,暂时无法提供与“P136-000-1”相匹配的价格&库存,您可以联系我们找货
P136-000-1
  • 1+215.012731+27.86975
