P134-000-DVI-V2
P134-000-DVI-V2
    TRIPPLITE
    DISPLAYPORTMALETODVIFEMALE
P134-000-DVI-V2 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States DisplayPort 1.2 to DVI Compact Adapter Video Converter (M/F) MODEL NUMBER: P134-000-DVI-V2 Highlights ● Connect a DVI monitor to a computer with a DisplayPort output ● DisplayPort v1.2 to DVI Adapter Converter (DisplayPort-Male to DVI-I Female) ● Plug-and-play convenience; no drivers or software needed ● This product is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dualmode mode Package Includes ● Description Tripp Lite's P134-000-DVI-V2 DisplayPort v1.2 to DVI Adapter Converter allows you to connect a computer with a DisplayPort connection to a DVI monitor. Displayport v1.2 doubles the previous version bandwidth of 8.64 Gbps to 17.28 Gbps in High Bit Rate (HBR2) mode, which allows increased resolutions, higher refresh rates, and greater color depth. Fully molded one piece design ensures longer life. The P134-000-DVI-V2 is a passive adapter and requires that the connected computer has a DP++ (DisplayPort ++) dual-mode port, which allows HDMI and DVI signals to be passed through. Check the documentation for your DisplayPort source for compatibility. Features ● Connect a DVI monitor to a computer with a DisplayPort output ● DisplayPort v1.2 to DVI Adapter Converter (DisplayPort-Male to DVI-I Female) ● Supports DVI single-link computer video resolutions up to 1920 x 1080 (1080p) ● 17.28 Gbps bandwidth ● Fully molded one piece design ● Plug and Play; no drivers or software required ● Requires that the connected computer has a DP++ (DisplayPort ++) port, which allows HDMI and DVI signals to be passed through; check the documentation for your DisplayPort source for compatibility. Specifications OVERVIEW UPC Code 037332187550 Technology DVI; DisplayPort PHYSICAL Color Black 1/2 DisplayPort 1.2 to DVI Compact Adapter Converter (DP-Male to DVI-I Female) 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Dimensions (hwd / in.) 5.90 x 3.90 x 0.50 Shipping Dimensions (hwd / cm) 14.99 x 9.91 x 1.27 Shipping Weight (lbs.) 0.04 Shipping Weight (kg) 0.02 CONNECTIONS Side A - Connector 1 DISPLAYPORT (MALE) Side B - Connector 1 DVI-I (FEMALE) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
P134-000-DVI-V2 价格&库存
很抱歉,暂时无法提供与“P134-000-DVI-V2”相匹配的价格&库存,您可以联系我们找货
