U244-001-HDMI-R
U244-001-HDMI-R
    TRIPPLITE
    Adapter Connector USB - mini B Receptacle To HDMI, Receptacle Free Hanging (In-Line)
U244-001-HDMI-R 数据手册
USB 2.0 to HDMI Dual/Multi-Monitor External Video Graphics Card Adapter, 128 MB SDRAM, 1920 x 1080 (1080p) @ 60hz Highlights ● Extend video to a second display or duplicate one video on both ● Add up to 6 adapters to connect a total of 7 displays ● No external power supply needed ● Supports HD video resolutions up to 1920 x 1080 (1080p) @ 60hz ● Compatible with Windows and Mac computers ● Compatible with Ubuntu 14.04.2 MODEL NUMBER: U244-001-HDMI-R System Requirements ● Computer with USB 2.0 port ● HDMI-enabled display ● Windows 7 or later, Windows 10 (32- or 64-bit), Intel Mac OS X 10.8.3 or later. Mac 10.11 (32or 64-bit) or Surface tablet running non-RT Windows 8 or 8.1 Connect an HDTV or HDMI-enabled monitor or projector to the USB 2.0 port of your computer or laptop. Use up to 6 adapters to connect up to 6 additional displays to a source. Ideal for multitasking, presentations and editing documents. Package Includes ● U244-001-HDMI-R USB 2.0 to HDMI External Video Graphics Card Adapter The U244-001-HDMI-R USB 2.0 to HDMI External Video Graphics Card Adapter displays video on an ● USB cable, 3 ft. HDTV or HDMI-enabled monitor or projector via your computer or laptop’s USB 2.0 port. You can extend ● Quick Start Guide video from your primary display to another, duplicate the same video on both displays or change the ● Driver CD with Owner’s Manual Description second display to your primary display. The adapter is an ideal tool for multitasking, viewing large spreadsheets, editing documents, giving presentations at trade shows or watching movies and playing games on large screens. You can add up to six U244-001-HDMI-R adapters, each attached to its own USB 2.0 port, to connect a total of seven displays to the video source. Adding or removing a monitor is easy—no need to reboot the system afterward. No external power supply is necessary. First, install the drivers using the included CD. Then, connect the adapter to the display and the source using an HDMI cable and the included USB 2.0 cable, respectively. The U244-001-HDMI-R supports high-definition video resolutions up to 1920 x 1080 (1080p) @ 60hz and features 128 MB DDR SDRAM of memory. Compatible with 32- and 64-bit Windows 7 and later, Windows 10. as well as 32- and 64-bit Intel Mac OS X 10.8.3 and later, Mac 10.11. The adapter also works with Surface tablets running Windows 8 Pro or later. Features Easy to Add Displays ● Extend video to a second monitor, duplicate the same video on both monitors, or make the second 1/3 monitor your primary display ● Ideal for multitasking, viewing spreadsheet data, editing documents, giving presentations, watching movies and playing video games ● Add up to 6 adapters, each connected to its own USB 2.0 port, for a total of 7 displays ● No external power supply necessary ● No need to reboot system after adding or removing a monitor Vibrant, Superior Video Quality ● Supports high-definition video resolutions up to 1920 x 1080 (1080p) @ 60hz ● Features 128 MB DDR SDRAM of memory ● Uses DisplayLink DL-165 chipset ● Resumes automatically from hibernation and suspend modes PC and Mac Compatible ● Works with 32- and 64-bit Windows 7 and later, Windows 10 ● Works with 32- and 64-bit Intel Mac OS X 10.8.3 and later, Mac 10.11 ● Works with Surface tablets running Windows 8 Pro or later Specifications OVERVIEW UPC Code 037332167637 Technology USB 2.0 (High Speed); HDMI PHYSICAL Color Black Shipping Dimensions (hwd / in.) 8.50 x 6.00 x 2.25 Shipping Dimensions (hwd / cm) 21.59 x 15.24 x 5.72 Shipping Weight (lbs.) 0.50 Shipping Weight (kg) 0.23 CONNECTIONS Side A - Connector 1 USB A (MALE) Side B - Connector 1 HDMI (FEMALE) WARRANTY Product Warranty Period (Worldwide) 3-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: 2/3 https://www.tripplite.com/products/product-certification-agencies 3/3
U244-001-HDMI-R
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
U244-001-HDMI-R 价格&库存
很抱歉,暂时无法提供与“U244-001-HDMI-R”相匹配的价格&库存,您可以联系我们找货
