T020-001-SC10G
T020-001-SC10G
    TRIPPLITE
    T020-001-SC10G
T020-001-SC10G 数据手册
FC to SC 50/125 OM3 10 Gb Adapter for MultiFunction Optical Fiber Cable Tester (M/F) MODEL NUMBER: T020-001-SC10G Highlights ● Converts native FC jack to an SC female connector ● FC male plug connects to fiber cable tester’s FC female jack ● Perfect for 50/125 OM3 multimode cable testing ● Included dust caps keep connectors clean ● For use with T020-001-PSF Optical Fiber Cable Tester System Requirements ● Tripp Lite T020-001-PSF MultiFunction Optical Fiber Cable Tester Package Includes ● Converts FC connector on Tripp Lite Multi-Function Optical Fiber Cable Tester to an SC connector. Ideal for cable installers or anyone else working in telecom or LAN environments. Description The T020-001-SC10G FC to SC 10 Gb Adapter converts a native FC fiber female port on the Tripp Lite T020-001-PSF Multi-Function Optical Fiber Cable Tester to an SC female port for 50/125 OM3 multimode cable testing. “OM3” is clearly labeled on the unit to differentiate the T020-001-SC10G from other adapters. Included dust caps keep the connectors clean when not in use. Features Converts Cable Tester’s FC Connector to an SC Connector ● Ideal for cable installers or anyone else working in telecom or LAN environments ● Perfect for 50/125 OM3 multimode cable testing ● FC male plug connects to cable tester’s FC female jack ● Included dust caps keep connectors clean ● For use with T020-001-PSF Multi-Function Optical Fiber Cable Tester Specifications OVERVIEW UPC Code 037332197627 Technology Multimode Optical Mode OM3 PHYSICAL Color Silver 1/2 T020-001-SC10G FC to SC 50/125 OM3 10 Gb Adapter Clad Diameter (microns) 125 Core Diameter (microns) 50 Shipping Dimensions (hwd / cm) 22.86 x 17.78 x 1.27 Shipping Dimensions (hwd / in.) 9.00 x 7.00 x 0.50 Shipping Weight (kg) 0.02 Shipping Weight (lbs.) 0.04 WARRANTY Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
T020-001-SC10G
PDF文档中的物料型号为:MAX31855KASA+。
器件简介为:这是一种冷端温度(CCT)数字输出的K型热电偶至数字转换器,具有内部冷结补偿。
引脚分配如下: 1. CSB/SDI(1脚):芯片选择/串行数据输入 2. SDO(2脚):串行数据输出 3. SCK(3脚):串行时钟 4. SO/CDT(4脚):串行输出/冷结检测 5. GND(5脚):地 6. V+(6脚):供电电压 7. TH+/RTD+(7脚):热电偶正 8. TH-/RTD-(8脚):热电偶负
参数特性包括:供电电压为3.0V至3.6V,最大电流消耗为1.2mA,工作温度范围为-40°C至+125°C。
功能详解:该器件能够测量K型热电偶温度,内置冷结补偿,支持SPI通信协议,适用于高精度温度测量。
应用信息:适用于高精度温度测量领域,如工业过程控制、医疗设备、环境监测等。
封装信息:该器件采用8引脚的SOIC封装。
T020-001-SC10G 价格&库存
很抱歉,暂时无法提供与“T020-001-SC10G”相匹配的价格&库存,您可以联系我们找货
