FC to SC 62.5/125 Adapter for Multi-Function
Optical Fiber Cable Tester (M/F)
MODEL NUMBER: T020-001-SC62
Highlights
Converts native FC jack to an
SC female connector
FC male plug connects to fiber
cable tester’s FC female jack
Perfect for 62.5/125 multimode
cable testing
Included dust caps keep
connectors clean
For use with T020-001-PSF
System Requirements
Tripp Lite T020-001-PSF MultiFunction Optical Fiber Cable
Tester
Package Includes
Converts FC connector on Tripp Lite Multi-Function Optical Fiber Cable Tester to an SC connector. Ideal
for cable installers or anyone else working in telecom or LAN environments.
Description
The T020-001-SC62 FC to SC 62.5/125 Adapter converts a native FC fiber female port on the Tripp Lite
T020-001-PSF Multi-Function Optical Fiber Cable Tester to an SC female port for 62.5/125 multimode
cable testing. “62.5/125” is clearly labeled on the unit to differentiate the T020-001-SC62 from other
adapters. Included dust caps keep the connectors clean when not in use.
Features
Converts Cable Tester’s FC Connector to an SC Connector
● Ideal for cable installers or anyone else working in telecom or LAN environments
Perfect for 62.5/125 multimode cable testing
FC male plug connects to cable tester’s FC female jack
Included dust caps keep connectors clean
For use with T020-001-PSF Multi-Function Optical Fiber Cable Tester
Specifications
OVERVIEW
UPC Code
037332197610
Technology
Multimode
PHYSICAL
Color
Silver
Clad Diameter (microns)
125
1/2
62.5/125 Adapter
Core Diameter (microns)
62.5
Shipping Dimensions (hwd / cm)
22.86 x 17.78 x 1.27
Shipping Dimensions (hwd / in.)
9.00 x 7.00 x 0.50
Shipping Weight (kg)
0.02
Shipping Weight (lbs.)
0.04
WARRANTY
Product Warranty Period
(Worldwide)
Lifetime limited warranty
© 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does
not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice.
Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies:
https://www.tripplite.com/products/product-certification-agencies
2/2
很抱歉,暂时无法提供与“T020-001-SC62”相匹配的价格&库存,您可以联系我们找货
