AE2-10
AE2-10
    GREENLEECOMMUNICATIONS(格林利)
    CONN ADAPT RCPT UCI-E2000 SMPLX
AE2-10 数据手册
ADAPTER, UCI, E2000 Fiber Optic Instrument Adapters - UCI Cat No: AE2-10 UPC No: 783310606987 Description • • • • • • • "UCI Adapters Provide Direct Connectivity For Tempo FiberTOOLS To A Wide Range Of Industry-Standard Fiber Optic Connectors Adapter Design Ensures Maximum Accuracy And Repeatability When Performing Critical Measurements On Fiber Optic Systems Easy To Clean And Use Single-Mode And Multimode Compatible UCI Adapters Feature Durable Phosphor Bronze Alignment Sleeve UCI (Universal Connector Interface) Adapter Is Used On All 250/260 ?A"" Series SourcesAnd 330 Series Variable Optical Attenuators When using a hybrid adapter cable, the instrument UCI adapter and one end of the hybrid adapter cable should be a commonly available connector type. (i.E. FC, SC or ST) " Specifications • • • • Application : "Used On All 250/260 ?A"" Series Sources And 330 Series Variable Optical Attenuators " Fiber Type : E-2000 Material : Phosphor Bronze Alignment Sleeve Type : UCI
AE2-10 价格&库存
很抱歉,暂时无法提供与“AE2-10”相匹配的价格&库存,您可以联系我们找货
