ADAPTER, UCI FC
Fiber Optic Instrument Adapters - UCI
Cat No:
APC-108
UPC No:
783310605720
Description
"UCI Adapters Provide Direct Connectivity For Tempo FiberTOOLS To A Wide Range Of
Industry-Standard Fiber Optic Connectors
Adapter Design Ensures Maximum Accuracy And Repeatability When Performing Critical
Measurements On Fiber Optic Systems
Easy To Clean And Use
Single-Mode And Multimode Compatible
UCI Adapters Feature Durable Phosphor Bronze Alignment Sleeve
UCI (Universal Connector Interface) Adapter Is Used On All 250/260 ?A"" Series SourcesAnd 330
Series Variable Optical Attenuators
When using a hybrid adapter cable, the instrument UCI adapter and one end of the hybrid adapter
cable should be a commonly available connector type. (i.E. FC, SC or ST) "
Specifications
Application : "Used On All 250/260 ?A"" Series Sources And 330 Series Variable Optical
Attenuators "
Fiber Type : FC
Material : Phosphor Bronze Alignment Sleeve
Type : UCI
很抱歉,暂时无法提供与“APC-108”相匹配的价格&库存,您可以联系我们找货
