IMS5-02-02
IMS5-02-02
    SAMTEC(申泰)
    P=5mm
    5MM
IMS5-02-02 数据手册
(5.00 mm) .1969" PITCH • 30 A CABLE ASSEMBLY/COMPONENTS MPSS - NO. OF POSITIONS –02, –03, –04, –06, –08 - WIRE GAUGE –14 - - PLATING OPTION –L - –"XX.XX" = 10 µ" (0.25 µm) Gold on contact –16 ASSEMBLED LENGTH = Wire length in inches (83.00 mm) 03.25" min. –T - END 2 OPTION –SR (Available with –DR only) –DR = Notch up, straight = Single End –NUS = Double End = Matte Tin MPSS END 1 OPTION –NDS = Notch down, straight (10.16) .400 Board Mates: MPT SPECIFICATIONS Insulator Material: Nylon 6/6 Contact Material: Copper Alloy Plating: Au or Sn over 50 µ" (1.27µm) Ni Latch: Nylon 6/6 Operating Temp Range: -30 °C to +105 °C Voltage Rating: 600 VAC/848 VDC Wire: 14 or 16 AWG NO. OF POSITIONS A –02 (30.07) 1.184 –03 (35.07) 1.381 –04 (40.08) 1.578 –06 (50.09) 1.972 –08 (60.10) 2.366 A MPSS/MPT-V WIRE GAUGE CURRENT RATING (PER PIN) 14 AWG 19.7 A 16 AWG 15.9 A 1 PIN POWERED Assembled Length ± (3.2) .13 View complete specifications at: samtec.com?MPSS IMS5 - POSITIONS PER ROW - 02 SERIES CC46L –02, –03, –04, –06, –08 = Contact, Loose - WIRE GAUGE - 01 - –1416 = 14 to 16 AWG CC46R = Contact, Full Reel PLATING OPTION –L = 10 µ" (0.25 µm) Gold on contact –T = Matte Tin (18.56) .730 (22.59) .890 TOOLING Hand Tool: CAT-HT-246-1416-14 (14-16 AWG) Mini Applicator: CAT-MC-246-1416-XX-02 (14-16 AWG) Extraction Tool: CAT-EX-MPSS-01 Note: Some lengths, styles and options are non-standard, non-returnable View complete specifications at: samtec.com?IMS5, samtec.com?CC46L & samtec.com?CC46R samtec.com/PowerStrip Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
IMS5-02-02 价格&库存
很抱歉,暂时无法提供与“IMS5-02-02”相匹配的价格&库存,您可以联系我们找货
IMS5-02-02
    • 14+21.75836
    • 50+17.71029
    • 100+15.04967
    • 500+13.41739
    • 1000+11.23013
    库存:1661
    IMS5-02-02
      • 14+18.70812
      • 50+14.83030
      • 100+12.26478
      • 500+10.73391
      • 1000+8.98410
