BTMM-102-01-T-S-002
BTMM-102-01-T-S-002
    SAMTEC(申泰)
    .020SQ.RAPOSTASSEMBLY
BTMM-102-01-T-S-002 数据手册
F-215 SUPPLEMENT BTMM–145–01–T–D BTMM–110–01–T–D (2,00 mm) .0787" BTMM SERIES BTMM–106–01–T–S LOW PROFILE SQUARE POST JUMPER Choice of Single or Double row SPECIFICATIONS Up to 50 pins per row For complete specifications see www.samtec.com?BTMM Insulator Material: Black Liquid Crystal Polymer Terminal Material: Phosphor Bronze Plating: Sn over 50µ" (1,27µm) Ni Operating Temp Range: -55°C to +105°C RoHS Compliant: Yes Lead–Free Solderable: Yes (8,00 mm) .315" pitch (0,50 mm) .020" square RECOGNITIONS For complete scope of recognitions see www.samtec.com/quality (4,00 mm) .157" pitch (2,00 mm) .0787" pitch BTMM NO. PINS PER ROW 1 01 OTHER OPTION PLATING OPTION ROW OPTION –T –S “XXX” = Single Row = Polarized Position (Specify position of omitted pin) 01 thru 50 = Matte Tin –D = Double Row (Leave blank for no option) No. of positions x (2,00) .0787 02 (3,94) .155 (2,00) .0787 01 01 (0,50) .020 SQ (2,00) .0787 (1,50) .059 (1,50) .059 (4,00) .157 (2,57) .101 (8,00) .315 (4,00) .157 SINGLE ROW –S DOUBLE ROW Note: Some sizes, styles and options are non-standard, non-returnable. WWW.SAMTEC.COM Due to technical progress, all designs, specifications and components are subject to change without notice. (2,60) .102 –D
BTMM-102-01-T-S-002
物料型号: - BTMM–110–01–T–D - BTMM–145–01–T–D - BTMM–106–01–T–S
器件简介: - 低轮廓方柱跳线器,具有单排或双排选项,每排最多50个引脚。
引脚分配: - 引脚间距为2.00mm (0.0787"),引脚尺寸为2.00mm (0.0787") x 0.50mm (0.020")。
参数特性: - 绝缘材料:黑色液晶聚合物 - 端子材料:磷青铜 - 镀层:锡上镀50µ" (1.27µm) 镍 - 工作温度范围:-55°C 至 +105°C - 符合RoHS标准,无铅可焊
功能详解: - 提供了不同引脚数量和排列的跳线器选项,包括极化位置的指定。
应用信息: - 适用于需要低轮廓连接的应用。
封装信息: - 由于技术进步,所有设计、规格和组件可能会在不通知的情况下更改。
BTMM-102-01-T-S-002 价格&库存
很抱歉,暂时无法提供与“BTMM-102-01-T-S-002”相匹配的价格&库存,您可以联系我们找货
