Company Name:
Digi International
Customer Part Number:
984-63-052202
Mini PCI Express Socket
0.8Pitch 52P
Pinrex Part Number:
Description:
3FL-3,NO.16,LANE 609,SEC.5,CHUNG HSIN ROAD
SAN CHUNG CITY,TAIPEI HSIEN,TAIWAN R.O.C.
TEL : (02) 2999-9001
本公司通過 QA
FAX : (02) 2999-9002
ISO9000 及 140001 認証
ATTEND
SPECIFICATION
AND
PERFORMANCE
TECHNOLOGY INC.
SERIES: 119A
DATE:2007/5/30
PAGE:1/3
Scope:
This specification covers the requirements for product performance, test methods and quality
assurance provisions of Mini PCI Express.
Performance and Descriptions:
The product is designed to meet the electrical, mechanical and environmental performance
requirements specification. Unless otherwise specified, all tests are performed at ambient
environmental conditions.
ROHS:
All material in according with the ROHS environment related substances list controlled.
MATERIAL AND
FINISH
INSULATOR
Material
Housing: High Temperature Plastic UL94V-0
CONTACT
Material
Brass
Plating
Contact Plating: 3u” and 15u” selective gold.
Solder: Lead free.
Material
Latch: Stainless
SHELL OR COVER
Plating
OTHERWISE SPECIFIED
Voltage rating: 50VAC
Current: 0.5A
Operating Temperature: -55℃~+85℃
ATTEND
SPECIFICATION
AND
PERFORMANCE
TECHNOLOGY INC.
SERIES:119A
DATE:2007/5/30
PAGE:2/3
ELECTRICAL
Item
Requirement
Test Condition
Contact resistance
30 milliohms
Subject mated contacts assembled in housing to
closed circuit current of 10mA(max) at open circuit
voltage of 20mV voltage(Max).
Insulation resistance
500MΩ(Min)
Measured by applying 500VDC between adjacent
contacts of unmated connector.
Dielectric Strength
No breakdown
Current leakage:
0.5mA
Measured by applying 250VAC for one minute
between adjacent contacts of unmated connector
assemblies. MIL-STD-202 method 301
MECHANICAL
Item
Requirement
Test Condition
Vibration test
No electrical
discontinuity greater
than 1 microsecond.
ΔR=20mΩ Max
Physical shock
1.No electrical
than 1 microsecond
2.ΔR=20mΩ Max.
No physical damage.
Subject mated connectors to 10-55-10 Hz
traversed in 1 minute at 1.52mm amplitude 2 hours
each of 3 mutually perpendicular planes.
MIL-STD-202 method 201.
Subject mated connector to 50G’s,half-sine shock
pulses of 11 millisecond duration,3drops in each
PCB mating force
Durability
124pos.
51.5N(5.3Kgf) Max.
ΔR=20mΩ Max
direction applied along the 3 mutually perpendicular
planes total 18 drops.
MIL-STD-202 method 202.
Operation speed: 100mm/min measure the force
required to mate connectors.
Repeat insertion and extraction of PCB to and from
the connector with the turns to lock it and then
unlock it for 100 cycles.
ATTEND
TECHNOLOGY INC.
SPECIFICATION
AND
PERFORMANCE
SERIES:119A
DATE:2007/5/30
PAGE:3/3
SOLDER ABILITY
Item
Requirement
Solder ability
Wet solder coverage:
95% Min.
Resistance to
Soldering heat.
No physical damage.
Test Condition
Solder temperature: 260±5℃
Immersion duration: 3±0.5sec.
ENVIRONMENTAL
Item
Requirement
Humidity
1.Contact resistance:
△R=20mΩ Max
2.Insulation resistance:
500mΩ Min.
3.No physical damage.
Thermal shock
△R=20mΩ Max.
No physical damage
Test Condition
Expose the mated connectors to 40±2℃
Relative humidity 90~95% for 96 hours.
MIL-STD-202 method 103.
-55℃/30min and 85℃/30min.
Repeat 5 cycles.
很抱歉,暂时无法提供与“498-0090”相匹配的价格&库存,您可以联系我们找货
