MEC6-150-02-L-D-RA1
MEC6-150-02-L-D-RA1
    SAMTEC(申泰)
    SMD,P=0.64mm,卧贴
    0.64MM P数:100P
MEC6-150-02-L-D-RA1 数据手册
REVISION G DO NOT SCALE FROM THIS PRINT MEC6-1XX-02-X-D-RAX-XX (No OF POS x 0.635[.0250]) + 3.17[.125] REF C 1.90 .075 REF No OF POSITIONS (PER ROW) (No OF POS -1) x 0.635[.0250] -10, -18, -20, -30, -40 (SEE FIG 1) -50 (SEE FIG 2, SHEET 2) 0.635±0.050 .0250±.0020 (TYP) (TOL NON-ACCUM) CL 02 TAIL OPTION -RA1: STANDARD CARD THICKNESS -02: 1.57mm [.062] THICK CARD 80 79 0.635±0.050 .0250±.0020 (TYP) (TOL NON-ACCUM) (No OF POS -1) x 0.635[.0250] C 6.25 .246 REF C 0.85±0.08 .033±.003 (TYP) (No OF POS x 0.635[.0250]) + 1.57[.062] REF 1.78 .070 REF "A" ROW SPECIFICATION -D: DOUBLE (USE MEC6-XX-XX-D-RA1) PLATING -L: SELECTIVE LIGHT GOLD, MATTE TIN TAIL (USE C-173-01-L & C-174-03-L) -S: SELECTIVE GOLD, MATTE TIN TAIL (USE C-173-01-S & C-174-03-S) 7.40 .291 REF 01 OPTION -TR: TAPE & REEL (SEE FIG 3, SHT 2) C CL 0.85±0.08 .033±.003 (TYP) ROW 1 (C-173-01-X) ROW 2 (C-174-03-X) CL 0.95±0.15 .037±.006 C C C 2.65 .104 REF SEE TABLE 1 "A" POSITION #1 INDICATOR 0.10 .004 REF 0.95 .037 REF (TYP) 1.40 .055 REF SECTION "A"-"A" FOR POSITIONS -10, -20, -30 & -40 (MEC6-140-02-X-D-RA1 SHOWN) (No OF POS x 0.635[.0250]) + 1.77[.070] REF 1.05 .041 REF (TYP) 9.10 .358 REF FIG 1 0.90 .035 REF 3.54 .139 REF 5.78 .227 0.20 .008 REF (TYP) MEC6-XX-02-D-RA1 1.40 .055 REF CL CL DESIGNED & DIMENSIONED IN MILLIMETERS (INCHES FOR REFERENCE ONLY) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN MILLIMETERS. TOLERANCES ARE: DECIMALS ANGLES .X: 0.3 [.01] 2 .XX: 0.13 [.005] .XXX: 0.051 [.0020] NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. BURR ALLOWANCE: 0.038[.0015] MAX. 3. MINIMUM PUSHOUT FORCE: 2.22 N [.5 LB]. 4. PARTS TO BE PACKAGED IN TRAYS, UNLESS -TR OPTION IS SPECIFIED. F:\DWG\MISC\MKTG\MEC6-1XX-02-X-D-RAX-XX-MKT.SLDDRW MATERIAL: PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK CONTACT: PHOS BRONZE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 SHEET SCALE: 1:0.444444 DESCRIPTION: .635mm [.025"] RIGHT ANGLE EDGE CARD ASSEMBLY DWG. NO. MEC6-1XX-02-X-D-RAX-XX BY: DEAN P 05/12/2005 SHEET 1 OF 2 REVISION G C C 1.90 .075 REF 34.29±0.13 1.350±.005 19.05±0.13 .750±.005 POSITION 1 3.81 .150 0.635±0.050 .0250±.0020 (TOL NON-ACCUM) 02 100 01 99 OBLONG HOLE 0.635±0.050 .0250±.0020 (TOL NON-ACCUM) C C 19.05±0.13 .750±.005 USER DIRECTION OF UNREELING 3.81 .150 C 34.29±0.13 1.350±.005 FIG 3 38.09 1.500 REF -TR: TAPE & REEL PACKAGING VIEW (NOT DRAWN TO SCALE) 36.49 1.437 REF 21.06 .829 REF 13.44 .529 REF 36.69 1.444 REF CL PROPRIETARY NOTE THIS DOCUMENT CONTAINS INFORMATION CONFIDENTIAL AND PROPRIETARY TO SAMTEC, INC. AND SHALL NOT BE REPRODUCED OR TRANSFERRED TO OTHER DOCUMENTS OR DISCLOSED TO OTHERS OR USED FOR ANY PURPOSE OTHER THAN THAT WHICH IT WAS OBTAINED WITHOUT THE EXPRESSED WRITTEN CONSENT OF SAMTEC, INC. CL FIG 2 DO NOT SCALE DRAWING -50 POSITIONS MEC6-150-02-X-D-RA1 SHOWN (SAME AS FIG 1, UNLESS OTHERWISE STATED) SHEET SCALE: 1:0.4 F:\DWG\MISC\MKTG\MEC6-1XX-02-X-D-RAX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .635mm [.025"] RIGHT ANGLE EDGE CARD ASSEMBLY DWG. NO. MEC6-1XX-02-X-D-RAX-XX BY: DEAN P 05/12/2005 SHEET 2 OF 2
MEC6-150-02-L-D-RA1 价格&库存
很抱歉,暂时无法提供与“MEC6-150-02-L-D-RA1”相匹配的价格&库存,您可以联系我们找货
MEC6-150-02-L-D-RA1
  • 60+82.5909760+10.69842
