MEC1-120-02-F-D-EM2
MEC1-120-02-F-D-EM2
    SAMTEC(申泰)
    SMD,P=1mm
    特性:高达56 Gbps PAM4。PCI Express 4.0。适用于 (1.60 mm) .062" 和 (2.36 mm) .093" 厚的卡。可选间距:0.50 mm、0.635 mm、0....
MEC1-120-02-F-D-EM2 数据手册
REVISION R MEC1-1XX-XX-XX-D-EMX-XX No OF POSITIONS -05, -08, -20, -30, -40, -50, -60 & -70 (PER ROW) CARD SLOT THICKNESS -02: .062 THICK CARD (USE MEC1-XX-S-D-EMX-X) (SEE TABLE 1) DO NOT SCALE FROM THIS PRINT ((No OF POS + 2) x .03937[1.0000]) + .490[12.45] REF ((No OF POS + 2) x .03937[1.0000]) + .100[2.54] REF .2680 6.81 REF -F: FLASH GOLD (USE C-150-07-F-P) -L: LIGHT SELECTIVE GOLD ROW SPECIFICATION (USE C-150-07-L-P) -D: DOUBLE -S: SELECTIVE GOLD (USE MEC1-XX-X-D-EMX-X) (USE C-150-07-S-P) -FM: FLASH GOLD SELECTIVE, MATTE TIN TAIL (USE C-150-07-F-P) * NOT ENGINEERING APPROVED -LM: LIGHT SELECTIVE GOLD, MATTE TIN TAIL (USE C-150-07-L-P) -SM: SELECTIVE GOLD, MATTE TIN TAIL C (USE C-150-07-S-P) "A" REF 01 'A' .0500 1.27 REF (No OF POS + 2) x .03937[1.000] REF [BREAKOUT VIEW] EDGE MOUNT OPTION -EM1: .031 THICK PCB -EM2: .062 THICK PCB (SEE TABLE 3) PLATING 02 .0400 1.02 REF OPTIONS -NP: NO POLARIZED POSITION (USE MEC1-XX-X-D-EMX-N) (ONLY AVAILABLE ON -05, -08, -20 & -30 POSITIONS) -TR: ( SEE PAGE 2 -TR PACKAGE VIEW, NOT AVAILABLE FOR -60 OR -70 POS.) -BLANK: BODY IS POLARIZED +.005 "G" "A" +0.13 .021 - .010 0.53 - 0.25 C MEC1-XX-X-D-EMX-X .005 [.13] .003 [.08] .1690 4.29 REF .3500 8.89 REF .1850 4.70 REF .100±.010 2.54±0.25 REF "D" .010 (SEE NOTE 5) C "A" "C" REF .0394 1.000 (TYP) .3200 8.13 REF C-150-07-XX-P "F" 'B' .006[.015] (TYP) 2 MAX SWAY C (No OF POS -1) x .03937[1.0000] "E" .0140 0.36 REF 2 MAX SWAY (No OF POS x .03937[1.0000]) + .389[9.87] REF C "B" .007 (SEE NOTE 5) SECTION "A"-"A" [SEE CONTACT IN-PROCESS VIEW] .0300 0.76 REF DETAIL 'A' SCALE 6 : 1 .1800 4.57 REF (TYP) NOTES: 1. 2. 3. 4. 5. 6. 7. 8. 9. C REPRESENTS A CRITICAL DIMENSION. BURR ALLOWANCE: .0015[.038] MAX. MINIMUM PUSHOUT FORCE: .5 LB. DELETED. .020[.51] MAX VARIATION ON ONE PART. .0040[.102] MAX ALLOWABLE BURR ON TAILS. DELETED. .0050[.127] MAX BARB PROTRUSION BELOW BODY. PART TO BE TRAY PACKAGED USING TRAY-XX-01. .1238 3.14 REF .0400 1.02 REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, COLOR: BLACK CONTACT: PHOS BRONZE F:\DWG\MISC\MKTG\MEC1-1XX-XX-XX-D-EMX-XX-MKT.SLDDRW SHEET SCALE: 1.75:1 DESCRIPTION: 1mm MINI-EDGE, EDGE MOUNT ASSEMBLY DWG. NO. MEC1-1XX-XX-XX-D-EMX-XX BY: KEVIN B 5/19/2000 SHEET 1 OF 3 REVISION R CONTACT IN-PROCESS FORM [-EM2] C .9449 24.00 REF [-EM1] C .0720 1.83 01 .0875 2.22 2.8346 72.00 REF R.0570 1.45 R.0570 1.45 .1000 2.54 .1100 2.79 105° 105° R.0200 0.51 CARRIER USER DIRECTION OF UN-REELING POCKET NOT DETAILED R.0270 0.69 R.0270 0.69 CARRIER - TR PACKAGING VIEW MEC1-130-02-*-D-EM2-TR SHOWN PACKAGING VIEW C [PARTS TO HAVE POSITION #1 LOADED IN SAME DIRECTION FOR ALL PARTS] .0050 0.13 MAX (SEE NOTE 8) DETAIL 'B' SCALE 7 : 1 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.75:1 F:\DWG\MISC\MKTG\MEC1-1XX-XX-XX-D-EMX-XX-MKT.SLDDRW DESCRIPTION: 1mm MINI-EDGE, EDGE MOUNT ASSEMBLY DWG. NO. MEC1-1XX-XX-XX-D-EMX-XX BY: KEVIN B 5/19/2000 SHEET 2 OF 3 REVISION R CARD SOLDER PAD .1510 3.84 REF .0468 1.19 REF .0480 1.22 REF .0300 0.76 REF SOLDER PAD PCB BOARD APPLICATION VIEW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 1.75:1 F:\DWG\MISC\MKTG\MEC1-1XX-XX-XX-D-EMX-XX-MKT.SLDDRW DESCRIPTION: 1mm MINI-EDGE, EDGE MOUNT ASSEMBLY DWG. NO. MEC1-1XX-XX-XX-D-EMX-XX BY: KEVIN B 5/19/2000 SHEET 3 OF 3
