DESIGNED & DIMENSIONED
IN MILLIMETERS
(INCHES FOR REFERENCE ONLY)
REVISION E
DO NOT
SCALE FROM
THIS PRINT
ERI8-XXX-X-D-RA-XX
PLATING SPECIFICATION
"A" (REF)
2.34 .092
62
OPTION
-TR: TAPE & REEL
-K: KAPTON
No OF POSITIONS (PER ROW)
-019 & -031
TAIL OPTION
-RA: STANDARD
-S: SELECTIVE GOLD, MATTE TIN TAIL
(USE C-230-01-S & C-231-01-S)
"B" (2 PLCS)
C
0.80 .031 (TYP)
(TOL. NON-ACCCUM)
ROW SPECIFICATION
-D: DOUBLE
32
8.40 .331
(REF)
FIG 1
(ERI8-031-S-D-RA SHOWN)
CL
31
0.75 .030
01
62
"C" (2 PLCS)
C
0.80 .031 (TYP)
(TOL. NON-ACCUM)
2.16 .085
(REF)
0.79 .031
C 1.49±0.15 .059±.006
"D" (REF)
32
"A"
6.40 .252
(REF)
1.38±0.12 .054±.005
C
1.54±0.15 .061±.006
C
CL
3.35 .132 REF
1.00 .039
(REF)(TYP)
CL
C
"A"
01
31
"E" (REF)
0.30 .012 REF
(TYP)
2.95 .116
(REF)
POSITION #1
INDICATOR
SEE TABLE 1
C
0.23±0.10 .009±.004
(TYP)
1.10 .043
(REF)
C-231-01-S
C-230-01-S
0.20±0.10 .008±.004
(TYP)
C
0.44 .017
11.43 .450
REF
SECTION "A"-"A"
SCALE 5 : 1
1.32 .052
(REF)
1.32 .052
(REF)
ERI8-XXX-01-D-RA
CL
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN MILLIMETERS.
TOLERANCES ARE:
DECIMALS
NOTES:
1. C REPRESENTS A CRITICAL DIMENSION.
2. BURR ALLOWANCE: 0.038[.0015] MAX.
3. MINIMUM PUSHOUT FORCE: 2.22 N [.5 LB].
4. PARTS TO BE PACKAGED IN TRAYS, UNLESS
-TR OPTION IS SPECIFIED.
5. MEASURE AT BENDS.
ANGLES
.X: 0.3 [.01]
2
.XX: 0.13 [.005]
.XXX: 0.051 [.0020]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR: LCP, COLOR: BLACK
CONTACT: BeCu Alloy
F:\DWG\MISC\MKTG\ERI8-XXX-X-D-RA-MKT.SLDDRW
SHEET SCALE: 1:0.7
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
.800[.032] RIGHT ANGLE EDGE CARD ASSEMBLY
DWG. NO.
ERI8-XXX-X-D-RA
BY: C PIERCE
4/17/2007
SHEET 1 OF 3
IN PROCESS 3
REVISION E
(C-230-01-S)
IN PROCESS 1
(C-231-01-S)
C
90°±3°
C
0.60±0.16 .024±.006
R0.35 .014
C
R0.35 .014
1.94 .076
90°
C
90°±3°
1.39±0.16 .055±.006
C
R0.35 .014
C
C
R0.35 .014
7.44 .293
(REF)
90°
C
C
1.13 .045
(SEE NOTE 5)
IN PROCESS 4
0.15 .006
C
4.95 .195
(SEE NOTE 5)
C
C-230-01-S
C 0.75 .030
IN PROCESS 2
0.23±0.10 .009±.004
C (SEE NOTE 5)
7.53 .296
(REF)
IN PROCESS 5
C-231-01-S
0.20±0.10 .008±.004
(SEE NOTE 5)
C
(HEAT STAKE TAILS)
R0.20 .008 TYP
(SHEAR & HEAT
STAKE TAILS)
C
0.79 .031
7.22 .284
(REF)
PROPRIETARY NOTE
SHEET SCALE: 1:0.2
F:\DWG\SW\Newprod\Point8mm\Edge Rate I-O cable connector system\ERI8-RA\ERI8-XXX-X-D-RA_ASM.SLDDRW
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
ERI8-XXX-X-D-RA
BY: C PIERCE
4/17/2007
SHEET 2 OF 3
REVISION E
10.25 .404 REF
K-DOT-.404-.500-.005
0.93±0.51 .037±.020
"F"±0.51 [.020]
5.9 .23
CL
FIG 2
(ERI8-031-S-D-RA-K SHOWN)
PROPRIETARY NOTE
SHEET SCALE: 5:1
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
ERI8-XXX-X-D-RA
BY: C PIERCE
4/17/2007
SHEET 3 OF 3
很抱歉,暂时无法提供与“ERI8-031-S-D-RA”相匹配的价格&库存,您可以联系我们找货
