MEC1-130-02-FM-D-A-K-TR 数据手册
REVISION AX
MEC1-1XX-XX-XX-D-XX-XX
"A" REF
.109 2.77
REF
16
02
.026 0.66
REF
40
.275 6.99
REF
PLATING SPECIFICATION
-F: 3µ" FLASH GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-L: 10µ" LIGHT GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-S: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
-FM: 3µ" FLASH GOLD IN CONATACT AREA,
MATTE ON TIN TAIL
-LM: 10µ" LIGHT IN CONTACT AREA,
MATTE TIN ON TAIL
-SM: 30µ" SELECTIVE GOLD IN CONTACT AREA,
MATTE TIN ON TAIL
.072 1.83 REF
01
C
.050 1.27
15
1.5° MAX SWAY
(ANY DIRECTION)
39
MEC1-XX-X-D-X-X
MEC1C-XX-X-D-X-X
(No OF POS +2) x
.03937 [1.00] REF
DO NOT
SCALE FROM
THIS PRINT
OTHER OPTIONS
-LC: LOCKING CLIP (SEE NOTE 8)
(SEE FIG 2)(USE LC-05-TM)
-A: ALIGNMENT PIN
(MOLDED, SEE FIG 4, SHT 2)
-K: POLYIMIDE FILM PAD
(SEE FIG 6, SHT 2)(USE K-DOT-.310-.406-.005)
-TR: TAPE & REEL PACKAGING
(N/A IN 70 POSITION)(SEE FIG 5, SHT 2)
(SEE NOTE 10)
-FR: FULL REEL QTY. TAPE & REEL
(N/A IN 70 POSITION)(SEE NOTE 11)
No OF POSITIONS
05, 08, 10, 20, 30, 40 , 50, 60 & 70
(PER ROW, SEE TABLE 1)
(MEC1C-XX-S-D-X-X ONLY AVAILABLE
IN 5 THRU 30 POSITIONS.)
(MUST USE MEC1-XX-S-D-X-X FOR AUTOMATION,
HAND-FILL PROCESS CAN USE EITHER)
CARD THICKNESS
FLOW INHIBITORS
AT VENDOR DISCRETION
-02: .062 [1.58] THICK CARD
(No OF POS -1) x .03937 [1.00]
"A"
POLARIZED OPTION (SEE TABLE 1)
-BLANK: BODY IS POLARIZED
-NP: NO POLARIZATION (-05 THRU -30 ONLY)
ROW SPECIFICATION
-D: DOUBLE ROW
C
+0.18
.020+-.007
.010 0.51 - 0.25
.350 8.89
REF
C
+.004
90°±3°
+0.10
.356 - .002 9.04 - 0.05
.006 0.15 REF
"A"
C-113-02-XX
.160 4.07
REF
SEE NOTE 2
.334 8.49
.320 8.13
REF
.030 0.75
.079 2.00
SECTION "A"-"A"
FIG 1
MEC1-120-02-X-D SHOWN
IN-PROCESS
IN-PROCESS
(FILL STEP)
(FOR HAND-FILL)
+.005
02
[+0.18] C
"B"+-.007
.005 [-0.13]
(SEE NOTES 5 & 9)
+0.13
0.00
01
.535 - .000 13.59
NOTES:
1. MINIMUM PUSHOUT FORCE: 10 oz.
2. COPLANARITY: POS -05 THRU -26: .004 [.10]
C
POS -27 THRU -70: .006 [.15]
3. C REPRESENTS A CRITICAL DIMENSION.
4. PACKAGE ALL POSITIONS IN TUBES UNLESS -TR OR -FR.
5. MAXIMUM CUT FLASH: .010; FLASH NOT TO EXTEND BELOW LEADS.
6. MAXIMUM ALLOWABLE BOW: .002 INCH/INCH AFTER ASSEMBLY.
7. MAXIMUM BURR: .003[.08], BURR DIRECTION TO BE OPPOSITE OF SOLDER PAD AREA
8. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT
COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT
FOR ALL ASSEMBLIES WITH THE –LC OPTION.
9. C1, OVERALL LENGTH, IS ONLY CONTROLLED BY THIS PRINT FOR CUT-TO-POSITION PARTS.
FOR MOLDED-TO-POSITION PARTS, REFERENCE THE COMPONENT PRINT.
10. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED
ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND
ON WWW.SAMTEC.COM.
11. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON
OPTIONS SELECTED.
12. PART ORIENTATION IN POCKET ONLY TO BE CHECKED ON HAND FILL PARTS.
40
(ROTO CUT)
(FOR HAND-FILL)
C
MEC1-XX-X-D-N-X
MEC1C-XX-X-D-N-X
39
FIG 3
-NP: NON-POLARIZED OPTION
(AVAILABLE ON -05, -08, -10, -20 & -30 POS. ONLY)
(SHOWN: MEC1-120-02-X-D-NP)
MEC1C-XX-X-D-X-X
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
ANGLES
.XX: .01 [.3]
2
.XXX: .005 [.13]
.XXXX: .0015 [.038]
MATERIAL:
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS CONFIDENTIAL AND
PROPRIETARY INFORMATION AND ALL DESIGN,
MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS
AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC,
INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE
OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR
REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY
OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS
WRITTEN CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
INSULATOR:
VECTRA E130i COLOR: BLACK
CONTACT:
BeCu 190 HM
F:\DWG\MISC\MKTG\MEC1-1XX-XX-XX-D-XX-XX-MKT.SLDDRW
SHEET SCALE: 2:1
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail: info@SAMTEC.com
code: 55322
DESCRIPTION:
1mm MINI-EDGE CARD ASSEMBLY
DWG. NO.
BY: KEVIN B
5/11/2000
SHEET 1 OF 2
FIG 5
REVISION AX
-TR: TAPE & REEL PACKAGING VIEW
(NOT DRAWN TO SCALE)
(SEE NOTE 12)
C
POSITION 1
.059 1.50 (TYP)
LC-05-TM
.010 0.25 REF
.056 1.42 REF (TYP)
2 MAX SWAY
(EITHER DIRECTION)
C
({(No OF POS +2) x .03937[1.00]}
+ .0490[1.245]) .005[.13]
FIG 2
-LC OPTION
(SHOWN: MEC1-120-02-X-D-LC)
.0625 1.588 REF
MEC1-XX-X-D-X-A
MEC1C-XX-X-D-X-A
.376 9.55 REF
USER DIRECTION OF UNREELING
.035 0.89 REF
(TYP)
.055 1.40 REF
({(No OF POS +2) x .03937[1.0000]}
+ .0490[1.245]) REF
.0625 1.59 REF
FIG 4
-A: ALIGNMENT PIN OPTION (MOLDED)
(SHOWN: MEC1-120-02-X-D-A)
FIG 6
"P"
02
01
PACKAGING VIEW
-K: POLYIMIDE FILM PAD OPTION
(SHOWN: MEC1-120-02-X-D-K)
"M"
TUBE: PT-MEC1001
PLUG: TP-29
.018±.020 0.44±0.51
16
15
40
39
.310 7.87
PROPRIETARY NOTE
.361 9.17
SHEET SCALE: 1.5:1
NOTE: "M" = USED MEASURED DIMENSION (REF)
"P" = {("M" - .310 [7.87]) / 2} .020 [.51]
PHONE: 812-944-6733
FAX: 812-948-5047
code: 55322
DESCRIPTION:
DWG. NO.
BY: KEVIN B
5/11/2000
SHEET 2 OF 2
