MEC1-108-02-L-D-A
MEC1-108-02-L-D-A
    SAMTEC(申泰)
    SMD,P=1mm
    1MM P数:16P
MEC1-108-02-L-D-A 数据手册
REVISION AX MEC1-1XX-XX-XX-D-XX-XX "A" REF .109 2.77 REF 16 02 .026 0.66 REF 40 .275 6.99 REF PLATING SPECIFICATION -F: 3µ" FLASH GOLD IN CONTACT AREA, MATTE TIN ON TAIL -L: 10µ" LIGHT GOLD IN CONTACT AREA, MATTE TIN ON TAIL -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL -FM: 3µ" FLASH GOLD IN CONATACT AREA, MATTE ON TIN TAIL -LM: 10µ" LIGHT IN CONTACT AREA, MATTE TIN ON TAIL -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL .072 1.83 REF 01 C .050 1.27 15 1.5° MAX SWAY (ANY DIRECTION) 39 MEC1-XX-X-D-X-X MEC1C-XX-X-D-X-X (No OF POS +2) x .03937 [1.00] REF DO NOT SCALE FROM THIS PRINT OTHER OPTIONS -LC: LOCKING CLIP (SEE NOTE 8) (SEE FIG 2)(USE LC-05-TM) -A: ALIGNMENT PIN (MOLDED, SEE FIG 4, SHT 2) -K: POLYIMIDE FILM PAD (SEE FIG 6, SHT 2)(USE K-DOT-.310-.406-.005) -TR: TAPE & REEL PACKAGING (N/A IN 70 POSITION)(SEE FIG 5, SHT 2) (SEE NOTE 10) -FR: FULL REEL QTY. TAPE & REEL (N/A IN 70 POSITION)(SEE NOTE 11) No OF POSITIONS 05, 08, 10, 20, 30, 40 , 50, 60 & 70 (PER ROW, SEE TABLE 1) (MEC1C-XX-S-D-X-X ONLY AVAILABLE IN 5 THRU 30 POSITIONS.) (MUST USE MEC1-XX-S-D-X-X FOR AUTOMATION, HAND-FILL PROCESS CAN USE EITHER) CARD THICKNESS FLOW INHIBITORS AT VENDOR DISCRETION -02: .062 [1.58] THICK CARD (No OF POS -1) x .03937 [1.00] "A" POLARIZED OPTION (SEE TABLE 1) -BLANK: BODY IS POLARIZED -NP: NO POLARIZATION (-05 THRU -30 ONLY) ROW SPECIFICATION -D: DOUBLE ROW C +0.18 .020+-.007 .010 0.51 - 0.25 .350 8.89 REF C +.004 90°±3° +0.10 .356 - .002 9.04 - 0.05 .006 0.15 REF "A" C-113-02-XX .160 4.07 REF SEE NOTE 2 .334 8.49 .320 8.13 REF .030 0.75 .079 2.00 SECTION "A"-"A" FIG 1 MEC1-120-02-X-D SHOWN IN-PROCESS IN-PROCESS (FILL STEP) (FOR HAND-FILL) +.005 02 [+0.18] C "B"+-.007 .005 [-0.13] (SEE NOTES 5 & 9) +0.13 0.00 01 .535 - .000 13.59 NOTES: 1. MINIMUM PUSHOUT FORCE: 10 oz. 2. COPLANARITY: POS -05 THRU -26: .004 [.10] C POS -27 THRU -70: .006 [.15] 3. C REPRESENTS A CRITICAL DIMENSION. 4. PACKAGE ALL POSITIONS IN TUBES UNLESS -TR OR -FR. 5. MAXIMUM CUT FLASH: .010; FLASH NOT TO EXTEND BELOW LEADS. 6. MAXIMUM ALLOWABLE BOW: .002 INCH/INCH AFTER ASSEMBLY. 7. MAXIMUM BURR: .003[.08], BURR DIRECTION TO BE OPPOSITE OF SOLDER PAD AREA 8. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION. 9. C1, OVERALL LENGTH, IS ONLY CONTROLLED BY THIS PRINT FOR CUT-TO-POSITION PARTS. FOR MOLDED-TO-POSITION PARTS, REFERENCE THE COMPONENT PRINT. 10. -TR OPTION ORDERS INVOLVING PARTIAL REEL QUANTITIES MAY BE PACKAGED ACCORDING TO THE SAMTEC PACKAGING EFFICIENCY STANDARDS (SPES) FOUND ON WWW.SAMTEC.COM. 11. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. 12. PART ORIENTATION IN POCKET ONLY TO BE CHECKED ON HAND FILL PARTS. 40 (ROTO CUT) (FOR HAND-FILL) C MEC1-XX-X-D-N-X MEC1C-XX-X-D-N-X 39 FIG 3 -NP: NON-POLARIZED OPTION (AVAILABLE ON -05, -08, -10, -20 & -30 POS. ONLY) (SHOWN: MEC1-120-02-X-D-NP) MEC1C-XX-X-D-X-X UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0015 [.038] MATERIAL: * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: VECTRA E130i COLOR: BLACK CONTACT: BeCu 190 HM F:\DWG\MISC\MKTG\MEC1-1XX-XX-XX-D-XX-XX-MKT.SLDDRW SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 1mm MINI-EDGE CARD ASSEMBLY DWG. NO. MEC1-1XX-XX-XX-D-XX-XX BY: KEVIN B 5/11/2000 SHEET 1 OF 2 FIG 5 REVISION AX -TR: TAPE & REEL PACKAGING VIEW (NOT DRAWN TO SCALE) (SEE NOTE 12) C POSITION 1 .059 1.50 (TYP) LC-05-TM .010 0.25 REF .056 1.42 REF (TYP) 2 MAX SWAY (EITHER DIRECTION) C ({(No OF POS +2) x .03937[1.00]} + .0490[1.245]) .005[.13] FIG 2 -LC OPTION (SHOWN: MEC1-120-02-X-D-LC) .0625 1.588 REF MEC1-XX-X-D-X-A MEC1C-XX-X-D-X-A .376 9.55 REF USER DIRECTION OF UNREELING .035 0.89 REF (TYP) .055 1.40 REF ({(No OF POS +2) x .03937[1.0000]} + .0490[1.245]) REF .0625 1.59 REF FIG 4 -A: ALIGNMENT PIN OPTION (MOLDED) (SHOWN: MEC1-120-02-X-D-A) FIG 6 "P" 02 01 PACKAGING VIEW -K: POLYIMIDE FILM PAD OPTION (SHOWN: MEC1-120-02-X-D-K) "M" TUBE: PT-MEC1001 PLUG: TP-29 .018±.020 0.44±0.51 16 15 40 * 39 .310 7.87 PROPRIETARY NOTE .361 9.17 DO NOT SCALE DRAWING SHEET SCALE: 1.5:1 NOTE: "M" = USED MEASURED DIMENSION (REF) "P" = {("M" - .310 [7.87]) / 2} .020 [.51] * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. F:\DWG\MISC\MKTG\MEC1-1XX-XX-XX-D-XX-XX-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 1mm MINI-EDGE CARD ASSEMBLY DWG. NO. MEC1-1XX-XX-XX-D-XX-XX BY: KEVIN B 5/11/2000 SHEET 2 OF 2
MEC1-108-02-L-D-A
1. 物料型号:MEC1-1XX-XX-XX-D-XX,其中“XX”代表不同的配置选项。 2. 器件简介:文档描述了1mm Mini-Edge卡连接器,这是一种用于电子设备的连接器。 3. 引脚分配:提供了不同位置数量的引脚分配表,例如-05位置有3.4mm的引脚,-08位置有5.6mm的引脚等。 4. 参数特性:包括卡的厚度、引脚的公差、最大摇摆角度等。 5. 功能详解:文档详细描述了连接器的不同特性,如锁定夹(-LC)、对齐销(-A)、聚酰亚胺膜垫(-K)等。 6. 应用信息:提供了连接器的应用信息,如手填过程可以使用任何选项,自动化过程需要特定的选项。 7. 封装信息:描述了连接器的封装选项,如胶带和卷轴包装(-TR)、全卷数量(-FR)等。 8. 其他信息:包括最小推力、共面性、关键尺寸、包装要求等。
MEC1-108-02-L-D-A 价格&库存
很抱歉,暂时无法提供与“MEC1-108-02-L-D-A”相匹配的价格&库存,您可以联系我们找货
MEC1-108-02-L-D-A
  • 1+40.956911+5.30536
  • 25+36.1838325+4.68708
  • 50+32.0422450+4.15059
  • 100+28.62607100+3.70808
  • 500+26.93344500+3.48883
库存:22
MEC1-108-02-L-D-A
    • 1+33.12360
    • 10+32.22720
    • 30+31.64400
    库存:29
