CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS
PXK
TM
NPCAP
Surface Mount
Series
・Super low ESR, impedance and high heat resistance have been obtained by using
conductive polymer as electrolyte.
・Rated voltage range : 2.5 to 16Vdc, Capacitance range : 100 to 560µF
・Suitable for DC-DC converters, voltage regulators and decoupling applications used to
computer motherboards etc.
・RoHS Compliant
・Halogen Free
PXK
Downsized
PXE P36
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Surge Voltage
Leakage Current
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
-55 to +105℃
2.5 to 16Vdc
±20% (M)
Rated voltage×1.15V
Shall not exceed values shown in STANDARD RATINGS.
(at 20℃, 120Hz)
(at 105℃)
(at 20℃ after 2 minutes)
0.12 max.
(at 20℃, 120Hz)
Z(-25℃)/Z(+20℃)≦1.15
Z(-55℃)/Z(+20℃)≦1.25
(at 100kHz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 2,000 hours
(F46 : 1,000 hours) at 105℃.
Appearance
No significant damage
Capacitance change
≦±20% of the initial value
DF (tanδ)
≦150% of the initial specified value
ESR
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to the DC rated voltage at
60℃, 90 to 95% RH for 1,000 hours (F46 : 500hours).
Appearance
Capacitance change
DF (tanδ)
ESR
Leakage current
The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105℃ for 30 seconds
through a protective resistor(R=1kΩ) and discharge for 5 minutes 30 seconds.
Appearance
Capacitance change
DF (tanδ)
ESR
Leakage current
0.5% per 1,000 hours maximum (Confidence level 60% at 105℃)
Bias Humidity
Surge Voltage
Failure Rate
*Note : If any doubt arises, measure the leakage current after following voltage treatment.
Voltage treatment : DC rated voltage are applied to the capacitors for 120 minutes at 105℃.
◆DIMENSIONS [mm]
EX) 2.5V330µF
Code : A
P
C±0.2
W
B±0.2
φD±0.5
●Terminal
◆MARKING
0.3max.
L±0.3 (Note)
Size Code
E61
F46
F61
φD
5
6.3
6.3
L
5.8
4.5
5.8
A
5.3
6.6
6.6
B
5.3
6.6
6.6
C
5.9
7.2
7.2
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
P
1.4
1.9
1.9
K89A
330
2.5V
A±0.2
Note : L+0.1/-0.2 for F46
◆PART NUMBERING SYSTEM
1
2
3
4
A PXK
5
6
7
8
9
10
A RA
11
12
13
14
M
15
16
17
18
G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 330µF:331, 560µF:561)
Taping code
Terminal code
Voltage code (ex. 2.5V:2R5, 6.3V:6R3)
Series code
Category
Please refer to "Product code guide (conductive polymer type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
30
CAT. No. E1001N
TM
NPCAP
Surface Mount
PXKSeries
◆STANDARD RATINGS
WV
(Vdc)
2.5
4
6.3
16
Cap
(µF)
220
330
330
560
180
220
390
150
180
220
330
100
Size
code
Leakage current
(µA max./after 2min.)
F46
E61
F46
F61
F46
E61
F61
F46
E61
F46
F61
F61
300
412
700
700
360
440
780
472
567
700
1,040
320
ESR
Rated ripple current
(mΩ max./20℃, 100k to 300kHz) (mArms/105℃, 100kHz)
19
16
16
16
19
17
17
19
17
18
17
24
2,780
3,500
3,500
3,500
2,780
3,390
3,390
2,780
3,390
3,200
3,390
2,490
Part No.
APXK2R5ARA221MF46G
APXK2R5ARA331ME61G
APXK2R5ARA331MF46G
APXK2R5ARA561MF61G
APXK4R0ARA181MF46G
APXK4R0ARA221ME61G
APXK4R0ARA391MF61G
APXK6R3ARA151MF46G
APXK6R3ARA181ME61G
APXK6R3ARA221MF46G
APXK6R3ARA331MF61G
APXK160ARA101MF61G
31
CAT. No. E1001N
很抱歉,暂时无法提供与“APXK2R5ARA561MF61G”相匹配的价格&库存,您可以联系我们找货
