3.7V 50000RPM Small
Coreless Motor 716
SKU: 108990001
(images/product/3.7V 50000RPM Motor 716.jpg)
(https://www.kickstarter.com/projects/seeed/wiolink-3-steps-5-minutes-build-your-iotapplicat/description?ref=banner_depot)
Description
It mainly used in small-scale aircraft, it's incredible that such a small motor can provide power 5W and
running the speed at 50000rpm on 3.7V. It's only 2.5g weight can effectively reduction the weight of the
aircraft .
Specification:
•Diameter: 7 mm
•Length: 16.5 mm
•Shaft length: 6.3 mm
•Shaft diameter: 0.8 mm
•Weight: 2.5 g
•Speed: 50000 rpm
•Rated voltage: 3.7 V
•Rated current: 100mA
•Wire length: 50 mm
For any technical support or suggestion, please kindly go to our forum
(http://www.seeedstudio.com/forum/viewforum.php?f=57).
Overview
(http://www.seeedstudio.com/depot/Shenzhen-2U-t-11.html?ref=pinfo)
Designer: Others
Other Products From
This Designer
(http://www.seeedstudio.com/depot/Others-m-24.html?ref=pinfo)
Weight: 4 g
http://www.seeedstudio.com/depot/37V-50000RPM-Small-Coreless-Motor-716-p-1884.ht...
12/3/2015
很抱歉,暂时无法提供与“108990001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+32.55120
- 200+12.60360
- 500+12.16080
- 1000+11.93400
