1143
1143
    ADAFRUIT
    直流电机 伺服电机 编码器 5VDC
1143 数据手册
  Micro Servo - MG90D High Torque Metal Gear PRODUCT ID: 1143 Add more power to your robot with this metal-geared MG90D servo. The tiny little servo can rotate approximately 90 degrees (45 in each direction), and works just like the standard kinds you're used to but smaller. You can use any servo code, hardware or library to control these servos. Good for beginners who want to make stuff move without building a motor controller with feedback & gear box, especially since it will fit in small places. Of course, its not nearly as strong as a standard servo. Works great with the Motor Shield for Arduino, our 16-channel Servo Driver, or by just wiring up with the Servo library. Comes with a few horns and hardware. Please note, this servo will 'hold' the position even when no signal is sent! To control with an Arduino, we suggest connecting the orange control wire to pin 9 or 10 and using the Servo library included with the Arduino IDE (see here for an example sketch). Position "0" (1.5ms pulse) is middle, "90" (~2ms pulse) is all the way to the right, "-90" (~1ms pulse) is all the way to the left. Note that the default servo pulse widths (usually 1ms to 2ms) may not give you a full 180 degrees of motion. In that case, check if you can set your servo controller to custom pulse lengths and try 0.75ms to 2.25ms. You can try shorter/longer pulses but be aware that if you go too far you could break your servo! TECHNICAL DETAILS Details:  Size : 22.8 x 12.2 x 28.5 mm  Voltage : 4.8V to 6V DC  Weight: 13.4 grams  Speed : 0.1 sec/60degrees (at 4.8V), 0.08 sec/60 degrees (at 6.0V)  Stall Torque : At 4.8V: 2.1 kg-cm / 25 oz-in. At 6.0V: 2.4 kg-cm / 30.5 oz-in  Spline Count: 20 Revision History:  As of November 7, 2018 this item has been updated to have a new digital 13g metal gear, with a double ball bearing servo.                                       https://www.adafruit.com/product/1143/3‐22‐19
1143
物料型号为MG90D,这是一款微型伺服电机,具有高扭矩金属齿轮。
该产品适用于需要在小空间内添加动力的机器人项目。
器件简介: - 微型伺服电机,具有高扭矩金属齿轮。
- 旋转角度约为90度,可向每个方向旋转45度。
- 适用于Arduino等开发平台,易于控制。
引脚分配: - 控制线(橙色):连接至Arduino的9号或10号引脚。
参数特性: - 尺寸:22.8 x 12.2 x 28.5 mm - 电压:4.8V至6V直流 - 重量:13.4克 - 速度:4.8V时0.1秒/60度,6.0V时0.08秒/60度 - 堵转扭矩:4.8V时2.1 kg-cm / 25 oz-in,6.0V时2.4 kg-cm / 30.5 oz-in - 齿槽数:20
功能详解: - 即使在不发送信号的情况下,该伺服电机也能保持位置。
- 通过Arduino IDE中的Servo库控制,可以设定位置为0(中间)、90(最右)或-90(最左)。
- 标准伺服脉冲宽度可能无法实现全180度运动,可以通过设置自定义脉冲长度来实现。
应用信息: - 适合初学者使用,无需构建带有反馈和齿轮箱的电机控制器,尤其适合小空间应用。
- 与Arduino Motor Shield、16通道伺服驱动器或仅使用Servo库配合使用。
封装信息: - 包含几个安装角和硬件。
产品符合RoHS标准,有关产品的更多信息可访问Adafruit网站。
很抱歉,暂时无法提供与“1143”相匹配的价格&库存,您可以联系我们找货
