1201
1201
    ADAFRUIT
    TERM SCREW 6-32 2 PIN PCB
1201 数据手册
ROBOTICS & CNC / ROBOTICS Vibrating Mini Motor Disc PRODUCT ID: 1201 DESCRIPTION - *BZZZZZZZZZZ* Feel that? That's your little buzzing motor, and for any haptic feedback project you'll want to pick up a few of them. These vibe motors are tiny discs, completely sealed up so they're easy to use and embed. Two wires are used to control/power the vibe. Simply provide power from a battery or microcontroller pin (red is positive, blue is negative) and it will buzz away. Works from 2V up to 5V, higher voltages result in more current draw but also a stronger vibration. If you want to reduce the current draw/strength (for example, to control it directly from an Arduino pin) try putting a resistor (100 to 1000 ohms) in series. For full power control, a small PN2222 transistor can control a motor easily, some experimentation may be required! Vibrating Mini Motor Disc (6:47) http://www.adafruit.com/products/1201 7/16/2015
很抱歉,暂时无法提供与“1201”相匹配的价格&库存,您可以联系我们找货
