FIT0277
FIT0277
    DFROBOT
    12VLOWNOISEDCMOTOR146RPMW/
FIT0277 数据手册
  12V DC Motor 146rpm w/Encoder  (SKU: FIT0277)  Contents      1 Introduction 2 Specification 3 Sound testing 4 Encoder Diagram 5 Encoder Sample Code Introduction This is DFRobot customized high quality DC motor. The best part of this motor is that it is a quiet and high torque output motor with optical encoder buildin. The optical encoder gives 663 pluse per rotation which is able to sensor 0.54 degree rotation from the shaft. The resolutiont can meet a general PID speed control requirements. This motor is widely used in mobile robot area. Specification  Model:28PA51G            Working voltage:12V No load RPM (before gearbox):8000 rpm Gear ratio: 51:1 No load RPM (after gearbox): 146rpm@12V No load current: @ 12V: 0.23A Stall current:3.6A Rated torque @ 12V: 10kg.cm (139oz.in) Encoder Resolution: 13 PPR (663 PPR for gearbox shaft) Two phase hall encoder Size:123x36x36mm Weight: 270g Sound testing Our tests on a common environmental sound emissions shows that the motors have differences. While we thought of averaging the sound emission values, this would not be accurate. Thus we kept the highest value gathered from the tests. The lowest sound emissions reached an average of 57dBA on 40dB indoors environmental sound. These tests where not done in a Acoustic chamber. No load was applied. For all sound sensitive projects, a sound proof case is recommended for all mechanical parts. Encoder Diagram  Diagram for using encoder with Encoder Adapter Diagram for using encoder without Encoder Adapter Encoder Sample Code /* Pay attention to the interrupt pin,please check which microcontroller you use . http://arduino.cc/en/Reference/AttachInterrupt */ //The sample code for driving one way motor encoder const byte encoder0pinA = 2;//A pin -> the interrupt pin 2 const byte encoder0pinB = 4;//B pin -> the digital pin 4 byte encoder0PinALast; int duration;//the number of the pulses boolean Direction;//the rotation direction void setup() { Serial.begin(57600);//Initialize the serial port EncoderInit();//Initialize the module } void loop() { Serial.print("Pulse:"); Serial.println(duration); duration = 0; delay(100); } void EncoderInit() { Direction = true;//default -> Forward pinMode(encoder0pinB,INPUT); attachInterrupt(0, wheelSpeed, CHANGE);//int.0 } void wheelSpeed() { int Lstate = digitalRead(encoder0pinA); if((encoder0PinALast == LOW) && Lstate==HIGH) { int val = digitalRead(encoder0pinB); if(val == LOW && Direction) { Direction = false; //Reverse } else if(val == HIGH && !Direction) { Direction = true; //Forward } } encoder0PinALast = Lstate; if(!Direction) else duration++; duration--; } Powered By DFRobot © 2008-2017
FIT0277 价格&库存
很抱歉,暂时无法提供与“FIT0277”相匹配的价格&库存,您可以联系我们找货
