80180504
80180504
    CROUZET(高诺斯)
    MOTOR80WWITHHALLEFFECTS-WI
80180504 数据手册
02/11/2015 www.crouzet.com 57 mm square and Ø 57 mm - 463 mNm continuous with Hall effect sensors 100 W nominal at 24 V and 3200 rpm Part number 80180504 High power motors (up to 160 W continuous at 24 VDC) Suitable for voltages between 6 and 75 VDC Ideal for applications where the control electronics have to be remote due to the high ambient temperature Part numbers 80180504 Type Type References 100 W nominal at 24 V and 3200 rpm 801805 With BDE30 connections Specifications General characteristics Max. speed (rpm) Torque peak in (mNm) Maximum continuous torque (mNm) 10000 845* 340** Motor constant (mNm/W1/2) Electrical time constant (ms) Mechanical time constant (ms) Energy losses at peak torque (W) Torque/speed factor - zero impedance (mNm/ (rad/s) ) Friction torque (mNm) 78 Rotor inertia (gcm2) Thermal resistance (°C/W) 105 Max. coil temperature (oC) Integrated temperature sensor Number of phases Number of poles Ambient operating temperature (°C) Dielectric strength at 500 V DC (MΩ) Service life (h) Output ball bearing Weight (g) Length (mm) Protection index 120 2,6 1,7 117 6,1 25 3,8 Yes*** 3 (delta config) 4 -40 →70 1000 20000 Yes 1300 94 IP54 Comments Standard winding Phase-to-phase resistance (Ω) Voltage at peak torque (V) Current at peak torque (A) Torque constant (mNm/A) Back EMF constant (V/ (rad/s) ) Back EMF constant (V/Krpm) Inductance (mH) 0,44 ±12,5 % 7,2 16,3 52 ±10 % 0,052 5,45 ±10 % 1,15 ±30 % Comments Motor mounted on aluminium plate 254 x 254 x 10 mm thick to encourage heat flow * 10 sec. at 25 °C ambient temperature ** 25 °C ambient temperature and 120 °C winding temperature *** With the exception of part number 80180504 Dimensions (mm) 801805 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 80180504 : With BDE30 connections No Legend 4 holes M5 over Ø 40 mm - depth of thread : 4.5 mm - depth of hole 6.6 mm D : Ø8 - 0.010 mm- 0.020 mm L : 94.2 mm max. Dimensions (mm) Holding brake : 80180514 Holding brake : At power switch off - 0.5 Nm - 7 W - 24 V ± 10 % Weight : 250 g - AWG26 leads - 400 mm Curves Power/Power supply Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected www.crouzet.com 02/11/2015 No www.crouzet.com Legend Nominal power Supply voltage Speeds (rpm) Connections Forward No Legend Winding Connections Reverse Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 No www.crouzet.com Legend Winding Connections Part number 801805 Hall effect : Voltage range : 4.5 24 VDC Max. current : 20 mA Type of output : NPN open collector Not protected against connection errors Other information For other standard windings visit www.crouzet.com Precautions for use Not protected against connection errors Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Product adaptations Special shafts Lead length C12 connector built in 200, 500, 1000 points/revolution encoder Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: 80180504
80180504 价格&库存
很抱歉,暂时无法提供与“80180504”相匹配的价格&库存,您可以联系我们找货
