80180506
80180506
    CROUZET(高诺斯)
    MOTOR120WWITHHALLEFFECTS(51
80180506 数据手册
02/11/2015 www.crouzet.com 57 mm square and Ø 57 mm - 463 mNm continuous with Hall effect sensors 120 W nominal at 24 V and 4000 rpm Part number 80180506 High power motors (up to 160 W continuous at 24 VDC) Suitable for voltages between 6 and 75 VDC Ideal for applications where the control electronics have to be remote due to the high ambient temperature Part numbers 80180506 Type Type References 120 W nominal at 24 V and 4000 rpm 801805 Without option Specifications General characteristics Max. speed (rpm) Torque peak in (mNm) Maximum continuous torque (mNm) 10000 763* 307** Motor constant (mNm/W1/2) Electrical time constant (ms) Mechanical time constant (ms) Energy losses at peak torque (W) Torque/speed factor - zero impedance (mNm/ (rad/s) ) Friction torque (mNm) 70 Rotor inertia (gcm2) Thermal resistance (°C/W) 105 Max. coil temperature (oC) Integrated temperature sensor Number of phases Number of poles Ambient operating temperature (°C) Dielectric strength at 500 V DC (MΩ) Service life (h) Output ball bearing Weight (g) Length (mm) Protection index 120 2,1 2,1 117 4,96 25 3,8 Yes 3 (delta config) 4 -40 →70 1000 20000 Yes 1300 94 IP54 Comments Standard winding Phase-to-phase resistance (Ω) Voltage at peak torque (V) Current at peak torque (A) Torque constant (mNm/A) Back EMF constant (V/ (rad/s) ) Back EMF constant (V/Krpm) Inductance (mH) 0,36 ±12,5 % 6,5 18 42,4 ±10 % 0,0424 4,4 ±10 % 0,76 ±30 % Comments Motor mounted on aluminium plate 254 x 254 x 10 mm thick to encourage heat flow * 10 sec. at 25 °C ambient temperature ** 25 °C ambient temperature and 120 °C winding temperature Dimensions (mm) 801805 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 No www.crouzet.com Legend 4 holes M5 over Ø 40 mm - depth of thread : 4.5 mm - depth of hole 6.6 mm D : Ø8 - 0.010 mm - 0.020 mm L : 94.2 mm max. Curves Power/Power supply No Legend Nominal power Supply voltage Speeds (rpm) Connections Forward Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 No www.crouzet.com Legend Winding Connections Reverse No Legend Winding Connections Part number 801805 Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected 02/11/2015 www.crouzet.com Hall effect : Voltage range : 4.5 24 VDC Max. current : 20 mA Type of output : NPN open collector Not protected against connection errors Other information For other standard windings visit www.crouzet.com Precautions for use Not protected against connection errors Product adaptations Special shafts Lead length C12 connector built in 200, 500, 1000 points/revolution encoder Unless otherwise specified, the characteristics given are applicable to all or part of the product range selected Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Crouzet: 80180506
80180506 价格&库存
很抱歉,暂时无法提供与“80180506”相匹配的价格&库存,您可以联系我们找货
