80080005
80080005
    CROUZET(高诺斯)
    MOTOR80W24VDCDRIVEMOTOMATE
80080005 数据手册
02/11/2015 www.crouzet.com 80 W Motomate Motor direct drive Part number 80080005 Movement control for simple mechanisms All-in-one solution for quick integration Compact with high performance Intuitive programming with graphical function blocks Adapted for severe environments 12 pulses per revolution of the motor Independant torque control Uses the functionalities of TNi20 Part numbers Type Ratio Max. speed (rpm) Available torque (Nm) Specifications General characteristics Supply voltage (V) Max. current (A) Immunity from micro power cuts (ms) Operating temperature (°C) Protection index 24 (20 →37) 6 1 -20 →+40 IP 54 Programming Inputs / outputs Programming method Program size Program memory Program cycle time (ms) Real-time clock 4I/4/O Function blocks / SFC 128 Flash EEPROM 10 No Logic inputs Max. number Input impedance (kΩ) Logic 1 voltage threshold (V) Logic 0 voltage threshold (V) Response time (ms) 4 (I1 →I4) > 10 > 15
80080005 价格&库存
很抱歉,暂时无法提供与“80080005”相匹配的价格&库存,您可以联系我们找货
