U280-001-C2
U280-001-C2
    TRIPPLITE
    TABLET/PHONE USB CHARGER 5V 2.4A
U280-001-C2 数据手册
USB Tablet / Phone Car Charger, 5V 2.4A / 12W Highlights ● Quickly charges a Tablet or Phone with up to 2.4A of power ● 5V 2.4A USB port MODEL NUMBER: U280-001-C2 System Requirements ● Automobile 12V DC Lighter Socket Package Includes ● Charge your Tablet and Phone in your car. Description Tripp Lite’s 2.4Amp USB Car Charger allows you to quickly and safely charge a USB-powered device and is ideal for ultra-fast charging devices such as iPad (including iPad Mini), other tablets, and cellular phones. This high-quality and ultra-compact charger works with any standard in-vehicle power outlet and features a translucent ring around the USB port that glows blue to indicate power is being passed through to your device. It is a handy tool to keep your devices fully-charged and ready to use while you are on-thego. Features ● High-speed 2.4A USB port for charging devices, including iPads, tablets, eReaders, smartphone's and more ● Works with any 12V DC auto lighter socket ● Use your existing USB cables to charge all devices ● 5V 2.4A USB port Specifications OVERVIEW UPC Code 037332184276 Product Type Car Charger Charging Form Factor Direct Plug-In Device Compatibility Phone; Tablet; Amazon Kindle Technology USB INPUT Nominal Input Voltage(s) Supported 12V DC 1/3 2.4A Single USB Car Charger Input Connection Type Automatic Vehicle Cigarette Lighter Input Plug Type Car Auxiliary Power Outlet OUTPUT Output Watt Capacity (Watts) 12 Overload Protection Yes CHARGING Number of Charging Ports 1 Total Charging Amps 1.4A Total Charging Watts 12 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports Details USB-A: 5V 2.4A (12W) Charging Ports / Amps (1) 2.4A Compatible Devices Laptop; Smartphone; Tablet PHYSICAL Color White Shipping Dimensions (hwd / in.) 1.00 x 4.10 x 6.10 Shipping Dimensions (hwd / cm) 2.54 x 10.41 x 15.49 Shipping Weight (lbs.) 0.06 Shipping Weight (kg) 0.03 Unit Dimensions (hwd / in.) 0.000 x 0.000 x 0.000 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range -40 to 176 F (-40 to 80 C) Operating Humidity Range 20 to 90% RH, Non-Condensing Storage Humidity Range 5 to 95% RH, Non-Condensing CONNECTIONS Number of Ports 1 Side A - Connector 1 Car Cigarette Lighter Side B - Connector 1 USB A (FEMALE) FEATURES & SPECIFICATIONS 2/3 Overcurrent Protection Yes Overvoltage Protection Yes GaN Technology No STANDARDS & COMPLIANCE Product Compliance CE (Europe); FCC (USA); RoHS WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 3/3
U280-001-C2
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为3x3mm。
U280-001-C2 价格&库存
很抱歉,暂时无法提供与“U280-001-C2”相匹配的价格&库存,您可以联系我们找货
