FIT0185
FIT0185
    DFROBOT
    12VDCMOTOR83RPMW/ENCODER
FIT0185 数据手册
  Metal DC Geared Motor w/Encoder - 12V 83RPM 45Kg.cm SKU: FIT0185 INTRODUCTION This is a Gear Motor w/Encoder, model No. GB37Y3530-12V-83R. It is a powerful 12V motor with a 131:1 metal gearbox and an integrated quadrature encoder that provides a resolution of 16 counts per revolution of the motor shaft, which corresponds to 2096 counts per revolution of the gearbox’s output shaft. These units have a 0.61" long, 6 mm(0.24")-diameter D- shaped output shaft. This motor is intended for use at 12V, though the motor can begin rotating at voltages as low as 1V. The face plate has six mounting holes evenly spaced around the outer edge threaded for M3 screws. These mounting holes form a regular hexagon and the centers of neighboring holes are 15.5 mm(0.61") apart. This motor is an ideal option for your mobile robot project. Warning: Do not screw too far into the mounting holes as the screws can hit the gears. Manufacturer recommends screwing no further than 3mm (1/8") into the screw hole. SPECIFICATION            Gear ratio: 131:1 No-load speed: 83 + 10% RPM No-load current: 350 mA Start Voltage: 1.0 V Stall Torque: 45 Kg.com Stall Current: 7 A Insulation resistance: 20 M Ω EncoderOperating Voltage: 5 V Encoder type: Hall Encoder Resolution: 16CPR(motor shaft)/2096CPR(gearbox shaft) Weight: 205g Powered By DFRobot © 2008-2017
FIT0185 价格&库存
很抱歉,暂时无法提供与“FIT0185”相匹配的价格&库存,您可以联系我们找货
FIT0185
  • 1+156.402141+20.25955
库存:140
