ROB-14210
ROB-14210
    SPARKFUNELECTRONICS
    SERVO-HITECHS-5035HD(ULTRAN
ROB-14210 数据手册
    Servo - Hitec HS-5035HD (Ultra Nano Size) ROB-14210 RoHS     Description: This is one of the smallest servos we carry, but don’t let its size fool you! The HS5035HD is the digital version of the popular HS-35HD and is destined to become a fan favorite! Equipped with a fully programmable digital circuit, Metal Karbonite gear train and long life potentiometer, the HS-5035HD provides heavy-hitting performance in a lightweight package. The HS-5035HD is able to take in 4.8 volts and deliver 11.11 oz-in of maximum torque at 0.1 sec/60°, and this guy is only about the size of a penny! This high-quality servo is perfect for your mechatronic needs, and if you are looking to get into robotics, this is where to start. The HS-5035HD servo comes standard with a 3-pin power and control cable and all hardware listed below. Note: Check the neutral position before linkage connection. Be advised that this servo is designed to rotate in 360° when the power is off due to its tiny structure. Check the “Neutral Position Warning Instruction” (included with each HS-5035HD) for more information. Features:           Voltage: 4.8 volts Torque: 11.11 oz-in Speed: 0.1 sec/60° Direction: Clockwise Rotation: 180° Bushing Bearing Dual Metal Karbonite Gears 3-Pole Ferrite Motor A1 Micro Spline Clear Enclosure Includes:       1x HS-5035HD Servo 3x Double Arm Micro Horn 1x Long Double Arm Micro Horn 1x Four Point Micro Horn 2x 4x9mm Phillips Screw 2x 3x5mm Phillips Screw Dimensions:    18.6mm x 7.6mm x 15.5mm Wire Length: 160mm Weight: 4.5g                                             https://www.sparkfun.com/products/14210  4/3/2017
ROB-14210 价格&库存
很抱歉,暂时无法提供与“ROB-14210”相匹配的价格&库存,您可以联系我们找货
