CSC32USBW
CSC32USBW
    TRIPPLITE
    Battery Charger Notebook 2.4A
CSC32USBW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Multi-Device Charging Cart, 32 USB Ports, iPad and Android Tablets, Wall-Mount Option, White MODEL NUMBER: CSC32USBW Highlights ● Fast 2.4A USB charging and syncing for 32 tablets ● Secures devices in locking, vented, wall-mountable steel cart ● Protective shelves with removable dividers and cord management ● Wide-grip handle and locking casters with non-marking wheels ● Ships ready for quick, easy installation Package Includes Locking steel cart provides 2.4A USB charging, syncing, secure storage and cord management for up to 32 tablets and other devices. Recommended for education, office, commercial, retail, industrial and healthcare environments. Features Fast Charging ● 32 USB ports provide fastest charging supported by each device, up to 2.4A per port ● Recommended for iPad, Android, Surface and Kindle tablets ● Also charges mobile phones and other USB devices ● Fits tablets with cases (up to 16.5 x 10.5 x 1.5 in. with cord) ● 10-ft. (3.05 m) AC input cord with NEMA 5-15P plug reaches distant outlets Convenient Syncing ● USB uplink port connects to host computer for wired syncing ● Supports wireless syncing and simultaneous syncing/charging (up to 1.5A per port during wired syncing) Comprehensive Protection ● Sturdy steel construction and powder-coated finish promote long-term durability ● Doors lock with included keys to help prevent device theft, damage or tampering ● 3-point locking mechanism latches doors at top, middle and bottom ● Built-in hasp and user-supplied padlock can replace or supplement built-in lock ● Rear ports accommodate user-supplied bicycle cable or chain lock ● Flow-through ventilation helps prevent devices from overheating ● Protective shelves specially coated to avoid device scratches and scuffs ● Cord access ports with rubber grommets protect against abrasions ● Solid top work surface helps avoid accidental drips and spills that could damage devices 1/4 ● CSC32USBW 32-Device USB Charging Station Cart, White ● Cart handle ● Input cord wrap ● Hex key ● Detachable 10-ft. (3.05 m) AC input cord ● Mounting hardware for handle and cord wrap ● (2) Keys ● Owner's manual 1000 Eaton Boulevard Cleveland, OH 44122 United States Clutter-Reducing Organization ● USB ports and charging cords store out of sight ● Shelves include charging cord access ports for each device ● Toolless trim panel permits quick access to cords Convenient Mobility ● Large swivel casters with non-marking wheels improve ride over uneven surfaces ● Casters lock to help prevent unwanted movement at rest ● Reversible wide-grip handle assists cart control ● Reversible cord wrap keeps input cord out of the way when moving cart ● Compact cart fits in same space as typical utility cart Flexible Configuration ● Ships ready for quick, easy installation—just attach handle and cord wrap ● Split front doors open 180 degrees for improved device and service access ● Rear-panel mounting slots support optional wall-mount installation ● Removable dividers accommodate thicker devices ● Firmware upgrade port for future updates Specifications OVERVIEW UPC Code 037332194695 Product Type Multi-Device Charger Charging Form Factor Mobile Cart Functions Charge; Secure; Sync Device Compatibility Tablet; Phone Device Slots 32 INPUT Nominal Input Voltage(s) Supported 120V AC Voltage Compatibility (VAC) 110; 120 Input Frequency 50 / 60 Hz (auto-select) Input Plug Type NEMA 5-15P Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 POWER Power Consumption (Watts) 112 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States CHARGING Number of Charging Ports 32 Total Charging Amps 80A Total Charging Watts 400 Charging Method USB Charging Port Type USB A (FEMALE) Charging Ports Details Pass through Charging Ports / Amps (32) 2.4A Overcharge Protection Yes Charging Amps per Port 2.4A PHYSICAL Color White Material of Construction Steel Charging Station Form Factor Mobile Cart Shipping Dimensions (hwd / in.) 39.96 x 23.62 x 33.66 Shipping Dimensions (hwd / cm) 101.50 x 59.99 x 85.50 Shipping Weight (lbs.) 155.43 Shipping Weight (kg) 70.50 Slot Dimensions - Bottom (hwd / in.) 10.5 x 1.5 x 15.4 Slot Dimensions - Bottom (hwd / mm) 267.3 x 38.2 x 390.5 Slot Dimensions - Top (hwd / in.) 10.5 x 1.5 x 15.4 Slot Dimensions - Top (hwd / mm) 267.3 x 38.2 x 390.5 Unit Dimensions (hwd / in.) 36.100 x 34.800 x 20.200 Unit Dimensions (hwd / cm) 91.69 x 88.39 x 54.86 (with handle installed) Unit Weight (lbs.) 130.67 Unit Weight (kg) 59.27 Number of Shelves 2 Assembly Required Yes FEATURES & SPECIFICATIONS Cord Management Yes Antimicrobial No EMI/RFI Line Noise Protection Yes Locking Yes 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Lock Type Key IP68 Rated No Built-In Circuit Breaker Yes Overcurrent Protection Yes Flow-Through Ventilation Yes UV Sterilization No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 60950-1 Product Compliance RoHS; CE (Europe); EIA/ECA-310-E; REACH; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty CATEGORY PAGE FILTERS (Y/N ONLY) External Receptacle No © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
CSC32USBW 价格&库存
很抱歉,暂时无法提供与“CSC32USBW”相匹配的价格&库存,您可以联系我们找货
