U280-016-RM
U280-016-RM
    TRIPPLITE
    TABLET/PHONE USB CHARGER 16 PORT
U280-016-RM 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States 16-Port USB Charging Station with Syncing Function - 5V 40A / 200W USB Charger Output, TAA Highlights ● Sync and charge up to 16 tablets, phones, or other mobile device ● Provides up to 5V, 2.4A (12 Watts) of power per port, for charging battery-intensive devices such as an iPad ● Charge your devices without the need to connect to a computer ● Sync your devices using their file management software, such as Apple iTunes or Apple Configurator ● Supports USB 2.0 data transfer rates up to 480Mbps ● Mounting hardware included for use in a rack installation ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases MODEL NUMBER: U280-016-RM System Requirements ● A tablet, phone, or other smart device (Note: The U280-016RM was designed to charge smart devices such as phones and tablets, and not for use with non-smart devices) ● A computer with an available USB port (if using the syncing function) ● For international use, a P054006 (Europe) or P056-006-10A (UK) can be purchased separately Description For the battery-intensive mobile devices of today, a standard USB hub is not sufficient for charging. Tripp Lite's U280-016-RM 16-Port Charger with Syncing Function is the solution, allowing you to charge up to 16 tablets, phones, or other mobile devices all at the same time. Up to 5V, 2.4A (12 Watts) of power is provided to each port, perfect for charging the most power hungry devices, such as the Apple iPad. In addition to charging, you can sync your devices using their file management software, such as Apple iTunes or Apple Configurator. So whether you're at home or in the office, you no longer need to run around looking for an available outlet, or unplug one device to charge the other, the U280-016-RM provides you with the ports and power you need. To ensure you stay current with technology, a firmware upgrade port is provided for future software upgrades. Constructed of heavy-duty, steel housing. Mounting hardware included for use in a rack installation. Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases. Package Includes Features ● U280-016-RM ● USB 2.0 A/B Device Cable ● C13 to 5-15P Power Cord Charge your devices without the need to connect to a computer ● Rubber Feet Sync your devices using their file management software, such as Apple iTunes or Apple Configurator ● Mounting Hardware ● Supports USB 2.0 data transfer rates up to 480Mbps ● Owner's Manual ● Firmware upgrade port is provided for future software upgrades ● Mounting hardware included for use in a rack installation ● Constructed of heavy-duty steel housing ● Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases ● ● ● ● Sync and charge up to 16 tablets, phones, or other mobile device Provides up to 5V, 2.4A (12 Watts) of power per port, for charging battery-intensive devices such as an iPad Specifications 1/4 1000 Eaton Boulevard Cleveland, OH 44122 United States OVERVIEW UPC Code 037332182715 Product Type Charging Station Charging Form Factor Rack Mount Device Compatibility Phone; Tablet; Amazon Kindle INPUT Nominal Input Voltage(s) Supported 120V AC; 240V AC Input Connection Type IEC320-C14 Voltage Compatibility (VAC) 100; 110; 120; 125; 127; 200; 208; 220; 230; 240 Input Frequency 50/60Hz Input Plug Type NEMA 5-15P Input Current 2.5A OUTPUT Overload Protection No POWER Power Consumption (Watts) 47 USER INTERFACE, ALERTS & CONTROLS LED Indicators Green (16x USB Charging, 1x Sync) CHARGING Number of Charging Ports 16 Total Charging Amps 40A Total Charging Watts 200 Charging Method USB Charging Port Type (16) USB A (FEMALE) Charging Ports Details USB-A: 5V/2.4A Charging Ports / Amps (16) 2.4A PHYSICAL Color Black Material of Construction Steel Shipping Dimensions (hwd / in.) 4.20 x 13.70 x 21.10 Shipping Dimensions (hwd / cm) 10.67 x 34.80 x 53.59 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Shipping Weight (lbs.) 10.70 Shipping Weight (kg) 4.85 Unit Dimensions (hwd / in.) 1.710 x 17.320 x 9.450 Unit Dimensions (hwd / mm) 440 x 240 x 43.5 Unit Packaging Type Box Unit Weight (lbs.) 7.5 Unit Weight (kg) 3.40 ENVIRONMENTAL Operating Temperature Range 32 to 104 F (0 to 40 C) Storage Temperature Range 5 to 122 F (-15 to 50 C) Relative Humidity 5% to 95% RH, Non-Condensing AC Mode Efficiency Rating (100% Load) 78.88 BTUs 160.6 BTU/Hr (Full Load) CONNECTIONS Number of Ports 16 Side A - Connector 1 (16) USB A (FEMALE) Side A - Connector 2 USB B (FEMALE) Side A - Connector 3 MICRO-USB B (FEMALE) Side B - Connector 1 IEC-320-C14; USB B (FEMALE) FEATURES & SPECIFICATIONS Driver Required No IP68 Rated No Overcurrent Protection No Overvoltage Protection No GaN Technology No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications CAN/CSA-C22.2 No. 60950-1 (Canada); IEC 60950-1; NOM (Mexico); UL 60950-1 Product Compliance RoHS; REACH; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
U280-016-RM 价格&库存
很抱歉,暂时无法提供与“U280-016-RM”相匹配的价格&库存,您可以联系我们找货
U280-016-RM
  • 1+5042.089781+652.32890
