CSC32ACW
CSC32ACW
    TRIPPLITE
    Battery Charger Notebook 12A
CSC32ACW 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Multi-Device Charging Cart, 32 AC Outlets, Chromebooks and Laptops, Wall-Mount Option, White Highlights ● Charges 32 Chromebooks and laptops up to 15 in. screen size ● Secures devices in locking, vented, wall-mountable steel cart ● Protective shelves with removable dividers and cord management ● Wide-grip handle and locking casters with non-marking wheels ● Ships ready for quick, easy installation MODEL NUMBER: CSC32ACW Package Includes Locking steel cart provides AC charging, secure storage and cord management for up to 32 Chromebooks and laptops. Recommended for education, office, commercial, retail, industrial and healthcare environments. Description The CSC32ACW 32-Device AC Charging Station Cart provides AC charging, secure storage and cord management for up to 32 Chromebooks and laptops. It's recommended for education, office, commercial, retail, industrial and healthcare environments. 32 AC outlets provide convenient charging for Chromebooks and laptops with a screen size up to 15 inches. Their AC adapters plug into the cart's 32 NEMA 5-15R outlets as needed, up to 1,440 total watts. The CSC32ACW also charges tablets and other USB devices through their power adapters. A built-in circuit breaker protects against overloads. The 10-ft. (3.05 m) AC input cord with NEMA 5-15P plug reaches distant outlets to help you place the cart in a convenient location. The cart promotes comprehensive device protection with steel construction and a white powder-coated finish for long-term durability. It locks with the included keys to help prevent device theft, damage or tampering, and flow-through ventilation helps prevent overheating. The cart also encourages clutter-reducing organization of devices and cabling. AC outlets, power adapters and cords store out of sight. Toolless trim panels permit quick service access. When moving devices from room to room, the cart provides convenient mobility. Large swivel casters with non-marking wheels improve the ride over uneven surfaces and lock to help prevent unwanted movement at rest. The reversible wide-grip handle assists cart control. The cart is easy to configure. It ships ready for quick, easy installation, and the handle and cord wrap attach on either side. The split front doors open 180 degrees for improved device and service access. Rear-panel slots support optional wall-mount installation, and removable shelf dividers accommodate thicker devices. Features Convenient ChargingCharges 32 Chromebooks and laptops up to 15 in. screen sizeDevice power adapters plug into NEMA 5-15R outlets (up to 1,440 watts total)Also charges tablets and other USB devices through their power adaptersBuilt-in circuit breaker protects against overloads10-ft. (3.05 m) AC input cord with NEMA 5-15P plug reaches distant outlets Comprehensive ProtectionSturdy steel construction and powder-coated finish promote long-term durabilityDoors lock with included keys to help prevent device theft, damage or tampering3-point locking mechanism latches doors at top, middle and bottomBuilt-in hasp and user-supplied padlock can replace or supplement built-in lockRear ports accommodate user-supplied bicycle cable or chain lockFlow-through 1/4 ● CSC32ACW 32-Device AC Charging Station Cart, White ● Cart handle ● Input cord wrap ● Hex key ● Mounting hardware for handle and cord wrap ● (2) Keys ● Owner’s manual 1000 Eaton Boulevard Cleveland, OH 44122 United States ventilation helps prevent devices from overheatingProtective shelves specially coated to avoid device scratches and scuffsCord access ports with rubber grommets protect against abrasionsSolid top work surface helps avoid accidental drips and spills that could damage devices Clutter-Reducing OrganizationAC outlets, power adapters and cords store out of sightToolless trim panels permit quick access to AC adapters and cordsShelves include charging cord access ports for each deviceStaggered outlets fit power adapters without blocking adjacent outlets Convenient MobilityLarge swivel casters with non-marking wheels improve ride over uneven surfacesCasters lock to help prevent unwanted movement at restReversible wide-grip handle assists cart controlReversible cord wrap keeps input cord out of the way when moving cartCompact cart fits in same space as typical utility cart Flexible ConfigurationShips ready for quick, easy installation—just attach handle and cord wrapSplit front doors open 180 degrees for improved device and service accessRear-panel mounting slots support optional wall-mount installationRemovable dividers accommodate thicker devices like battery chargers Specifications OVERVIEW UPC Code 037332193797 Product Type Multi-Device Charger Charging Form Factor Mobile Cart Functions Charge; Secure Device Compatibility Chromebook; Laptop Device Slots 32 INPUT Nominal Input Voltage(s) Supported 120V AC Voltage Compatibility (VAC) 120 Input Frequency 50 / 60 Hz Input Plug Type NEMA 5-15P Input Cord Length (ft.) 10 Input Cord Length (m) 3.05 CHARGING Number of Charging Ports 32 Charging Method AC Charging Port Type NEMA 5-15R Charging Ports Details Pass through Charging Ports / Amps (32) 12A Overcharge Protection No 2/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Charging Amps per Port 12A PHYSICAL Color White Material of Construction Steel Charging Station Form Factor Mobile Cart Shipping Dimensions (hwd / in.) 45.08 x 22.83 x 33.66 Shipping Dimensions (hwd / cm) 114.50 x 57.99 x 85.50 Shipping Weight (lbs.) 157.04 Shipping Weight (kg) 71.23 Slot Dimensions - Bottom (hwd / in.) 10.5 x 1.5 x 15.4 Slot Dimensions - Bottom (hwd / mm) 266.7 x 38.2 x 390.5 Slot Dimensions - Top (hwd / in.) 10.5 x 1.5 x 15.4 Slot Dimensions - Top (hwd / mm) 266.7 x 38.2 x 390.5 Unit Dimensions (hwd / in.) 36.100 x 34.800 x 20.200 Unit Dimensions (hwd / cm) 106.76 x 88.39 x 54.86 (with handle installed) Unit Weight (lbs.) 130.67 Unit Weight (kg) 59.27 Number of Shelves 2 Assembly Required Yes FEATURES & SPECIFICATIONS Cord Management Yes Antimicrobial No EMI/RFI Line Noise Protection No Locking Yes Lock Type Key IP68 Rated No Built-In Circuit Breaker Yes Overcurrent Protection Yes Flow-Through Ventilation Yes UV Sterilization No IP20 Rated No STANDARDS & COMPLIANCE Product Certifications NOM (Mexico); UL 1363 3/4 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS; CE (Europe); EIA/ECA-310-E; REACH; FCC Part 15 Class B (USA) WARRANTY & SUPPORT Product Warranty Period (Worldwide) 2-year limited warranty CATEGORY PAGE FILTERS (Y/N ONLY) External Receptacle No © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 4/4
CSC32ACW 价格&库存
很抱歉,暂时无法提供与“CSC32ACW”相匹配的价格&库存,您可以联系我们找货
