PRT-09835
PRT-09835
    SPARKFUNELECTRONICS
    BATTERYHOLDER-4XAATOBARREL
PRT-09835 数据手册
  Battery Holder - 4xAA to Barrel Jack Connector PRT-09 835 Description: This is a simple 4 cell AA battery holder. The 5 inch cable is terminated with a standard 5.5x2.1mm, center positive barrel jack connector. The connector mates with the barrel jack on the Arduino (among a number of other products) allowing you to easily make your project battery powered. Note: the average voltage regulator has about 1V of dropout (but can vary greatly). This pack, with normal alkaline batteries, will output ~5.5V causing a normal 5V board to run at around 4 to 4.5V. This depends a lot of what board and processor you are using with the battery pack. Please consult yer datasheet. https://www.sparkfun.com/products/9835 8/3/2016
PRT-09835 价格&库存
很抱歉,暂时无法提供与“PRT-09835”相匹配的价格&库存,您可以联系我们找货
PRT-09835
    • 1+53.20080
    • 200+21.23280
    • 500+20.52000
    • 1000+20.17440
