SPECIFICATIONS:
DESCRIPTION: POWER / SIGNAL - VERTICAL - MALE - MACHINED
1.543 [39.20]
1.311 [33.30]
Ø 0.120
2-PLACES
0.994 [25.25]
3
1 2
7
0.112 [2.84]
A1
4 5
8
9
6
ELECTRICAL:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
SIGNAL CONTACT RESISTANCE:
POWER CONTACT AMPERAGE:
SIGNAL CONTACT AMPERAGE:
5 GΩ MIN.
1000 VAC FOR 1 MIN
250V
-55°C TO +125°C
1.0 mΩ MAX.
10 mΩ MAX.
SEE P/N KEY
5 AMPS
MECHANICAL:
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE:
4.5 Kg MAX.
0.3 Kg MIN.
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SHELL:
HARDWARE:
NICKEL PLATED STEEL
NICKEL PLATED BRASS
230°C PROCESS TEMP.
10
10°
0.327 [8.30]
0.492 [12.50]
0.240 [6.10]
681M11W1103LYYY
0.031 [0.80]
0.433 [11.00]
0 = 40 AMP POWER // STANDARD PCB TAILS
1 = 40 AMP POWER // 2.22mm PCB TAILS
2 = 20 AMP POWER // STANDARD PCB TAILS
2
3
4
5
= NO HARDWARE
= 0.098" CN PCB SIDE
= 0.236" CN PCB SIDE
= 0.236" CN MATING SIDE
= 0.237" BOARDLOCK PCB SIDE
= 0.224" BOARDLOCK PCB SIDE
1 = GOLD FLASH
SEE SHEET 2
FOR CONTACT DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
07/18/2013
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
681M11W1103LYYY
3
NOTE:
SIGNAL AND POWER CONTACTS
COME PRE-LOADED INTO INSULATORS
DIMENSIONS(in/mm)
1.311 [33.30]
0.381 [9.68]
0.272 [6.91]
0.272 [6.91]
0.163 [4.14]
0&2
0.163 [4.14]
1
0.112 [2.84]
Ø 0.130 [Ø3.30]
2-PLACES
0.218
[5.54]
0.218
[5.54]
0.327
[8.31]
0.327
[8.31]
S
P
0.218
0.177
OPTION
0.381 [9.68]
5.55
4.50
0.118
0.087
3.02
2.22
SIGNAL CONTACTS
Ø 0.043 [Ø1.10]
10-PLACES
POWER CONTACTS
Ø 0.026 [Ø 0.65]
0.059 [1.50]
Ø 0.148 (40 AMP) [3.75]
Ø 0.110 (20 AMP) [2.80]
0.112 [2.84]
Ø 0.165 [Ø4.20]
1-PLACE
P
S
0.031 [0.80]
RECOMMENDED PCB LAYOUT
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
07/18/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
681M11W1103LYYY
3
TOLERANCE:
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
0 ..... NO HARDWARE
2 ..... 0.236" PCB SIDE
4 ..... 0.237" PCB SIDE
1 ..... 0.098" PCB SIDE
3 ..... 0.236" MATING SIDE
5 ..... 0.224" PCB SIDE
RoHS COMPLIANT
N
C
ALL DIMENSIONS ARE ±0.010
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
07/18/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
681M11W1103LYYY
3
很抱歉,暂时无法提供与“681M11W1103L001”相匹配的价格&库存,您可以联系我们找货
