DESCRIPTION: FEMALE // DIP SOLDER // HIGH PROFILE
DIMENSIONS (mm)
POSITIONS
A
B
C
D
E(REF)
F
9
30.81
24.99
16.33
7.90
15.45
11.45
15
39.19
33.32
24.66
7.90
24.50
11.45
25
53.04
47.04
38.38
7.90
37.83
11.45
37
69.32
63.50
54.84
7.90
54.45
11.45
50
67.00
61.10
52.20
10.90
51.85
11.40
MATERIAL:
SHELL:
INSULATOR:
PROCESS TEMP:
CONTACTS:
HARDWARE:
STEEL, NICKEL PLATED
UL 94V-O RATED, PBT-BLACK
230°C
BRASS - GOLD PLATED
NICKEL PLATED BRASS
ELECTRICAL:
CURRENT RATING: 5 AMPS
CONTACT RESISTANCE: 10 mOhms Max.
INSULATION RESISTANCE: 5,000 MOhms min.
WORKING VOLTAGE: 250VAC RMS
OPERATING TEMPERATURE: -55°C TO 100°C
172-YYY-28YLYY1
SERIES
POSITIONS
009
015
025
037
050
GENDER
2 = FEMALE
TERMINATION
8 = HIGH PROFILE VERTICAL
SHELL PLATING
3 = NICKEL (GROUND INDENTS)
RoHS COMPLIANT
HARDWARE OPTIONS
00 = NO HARDWARE
01 = 2.50mm CLINCH NUT (BOARD SIDE)
02 = 5.80mm CLINCH NUT (BOARD SIDE)
03 = 5.80mm CLINCH NUT (MATING SIDE)
PLATING OPTIONS
1 = GOLD FLASH
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = mm
DRAWN:
W. ROBBINS
DATE:
08/23/1998
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
2
172-YYY-28YLYY1
22
1.312
CL
0.984
CL
0.656
0.378
CL
0.492
0.216
0.108
0.112 (9, 15, 25, 37 POSITON)
0.270
0.162
0.054
0.054
Ø 0.043
0.926
0.652
0.544
0.435
Ø 0.126
MINIMUM
0.108
0.216
0.324
0.162
0.326
0.218
0.109
0.055
0.163
0.272
0.381
0.489
0.598
15 POSITION
9 POSITION
2.500
2.406
CL
CL
1.250
0.978
0.870
0.761
0.652
0.544
0.435
0.326
0.218
0.109
0.224
0.055
0.163
0.272
0.381
0.489
0.598
0.707
0.815
HARDWARE MOUNTING HOLES
MAY NOT BE REQUIRED DEPENDING
ON MOUNTING METHOD TO PCB
TYP.
SUGGESTED SIZE
MAY NOT BE SUITABLE FOR ALL APPLICATIONS
50 POSITION
37 POSITION
RoHS COMPLIANT
25 POSITION
1.203
0.870
0.761
0.652
0.544
0.435
0.326
0.218
0.109
0.055
0.163
0.272
0.381
0.489
0.598
0.707
0.815
0.924
N
C
1.852
UNITS = inch
DRAWN:
W. ROBBINS
DATE:
08/23/1998
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
2
172-YYY-28YLYY1
22
很抱歉,暂时无法提供与“172-037-283L021”相匹配的价格&库存,您可以联系我们找货
