172-E15-203R031
172-E15-203R031
    NORCOMP
172-E15-203R031 数据手册
DESCRIPTION: FEMALE - SOLDER CUP / MACHINED - ECONOMY DIMENSIONS(mm) SIZE A+0.39 -0.39 B+0.25 -0.25 C+0.25 -0.25 D+0.25 -0.34 E+0.38 -0.38 F+0.25 -0.25 9 30.81 24.99 16.33 7.90 12.55 10.80 15 39.19 33.32 24.66 7.90 12.55 10.80 25 53.04 47.04 38.38 7.90 12.55 10.80 37 69.32 63.50 54.84 7.90 12.55 10.80 50 67.00 61.10 52.20 10.90 15.40 13.30 172-EYY-20YRYY1 WILL ACCEPT 26-20 AWG WIRE MATERIAL: SHELL: INSULATOR: PROCESS TEMP.: CONTACT: NICKEL OR TIN PLATED STEEL PA6T, UL 94 V-0 260°C BRASS ELECTRICAL: CURRENT RATING: 5 AMPS CONTACT RESISTANCE: 15 mOhms Max. INSULATION RESISTANCE: 1,000 MOhms min. VOLTAGE: 500VAC FOR 1 MINUTE TEMPERATURE: -55° C TO 125° C RoHS COMPLIANT SERIES POSITIONS E09 E15 E25 E37 E50 GENDER 2 = FEMALE TERMINATION 0 = SOLDER CUP SHELL PLATING 2 = TIN (N/A FOR HW "01" / "02" / "03") 3 = NICKEL RoHS COMPLIANT HARDWARE OPTIONS 00 = NO HARDWARE 01 = .098" CLINCH NUT (SOLDER SIDE) 02 = .236" CLINCH NUT (SOLDER SIDE) 03 = .236" CLINCH NUT (MATING SIDE) 05 = .237" 4-40 BOARD LOCK 91 = .237" 4-40 SPACER/ BOARD LOCK PLATING OPTIONS 1 = GOLD FLASH 2 = 30µ" GOLD UNITS = mm DO NOT SCALE FROM DRAWING N C NorComp PAM JENKINS NTS 11-28-05 1 2 172-EYY-20YRYY1 15 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL DIMENSIONS ARE ±0.010 ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 01X ..... 0.098" (SOLDER SIDE) 02X ..... 0.236" (SOLDER SIDE) 03X..... 0.236" (MATING SIDE) 0.236 0.141 0.279 0.098 0.279 0.236 05X ..... 0.237" (SOLDER SIDE) 91X ..... 0.237" (SOLDER SIDE) 0.234 0.506 0.280 0.237 0.237 NOTE: 4-40 FEMALE SCREW LOCK IS REMOVABLE UNITS = INCH N C RoHS COMPLIANT DO NOT SCALE FROM DRAWING NorComp PAM JENKINS NTS 11-28-05 2 2 172-EYY-20YRYY1 15
172-E15-203R031 价格&库存
很抱歉,暂时无法提供与“172-E15-203R031”相匹配的价格&库存,您可以联系我们找货
172-E15-203R031
  • 1+52.060241+6.74273
  • 10+44.2698810+5.73374
  • 25+41.4971125+5.37462
  • 50+39.5150050+5.11790
  • 100+37.62945100+4.87369
  • 280+34.99235280+4.53214
  • 560+33.32321560+4.31595
  • 1120+31.733891120+4.11011
  • 2520+29.971392520+3.88183
库存:177
172-E15-203R031
    • 1+56.63520
    • 210+22.60440
    • 490+21.84840
    • 980+21.47040
