681S7W2203L001
681S7W2203L001
    NORCOMP
    7(5 + 2 电源) 位 D-Sub,组合式 插座,母形插口 连接器, 通孔 焊接
681S7W2203L001 数据手册
DESCRIPTION: POWER / SIGNAL - VERTICAL BOARD - FEMALE SPECIFICATIONS: ELECTRICAL: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: SIGNAL CONTACT RESISTANCE: POWER PINS: SIGNAL PINS: 1.543 ± 0.010 [39.20 ± 0.25] 1.311 ± 0.010 [33.30 ± 0.25] 0.969 ± 0.010 [24.60 ± 0.25] Ø 0.120 [3.05] 2-PLACES 0.538 [13.67] A2 2 5 4 0.112 [2.84] 0.492 ± 0.010 12.50 ± 0.25] 3 1.0 mΩ MAX. 10 mΩ MAX. 40 AMPS 5 AMPS MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SEAL: SHELL: HARDWARE: F08 FLEXIBLE ADHESIVE NICKEL PLATED STEEL NICKEL PLATED BRASS 0.311 ± 0.010 [7.90 ± 0.25] 10° 250V -55°C TO +125°C 230°C PROCESS TEMP. A1 1 5 GΩ MIN. 1000 VAC FOR 1 MIN 681S7W2203LYYY 0.109 [2.77] TYP. 0 = 40 AMP 0.228 [5.80] 0 = NO HARDWARE 4 = 0.237" BOARDLOCK PCB SIDE 0.031 ± 0.008 [0.80 ± 0.20] 0.421 [10.70] 1 = GOLD FLASH MEETS IP67 STANDARDS (SEE PAGE 2 FOR SEALING DETAILS) RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: P. JENKINS DATE: 07/19/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 681S7W2203LYYY 3 DESCRIPTION: 681 SERIES CONTACTS NOTE: SIGNAL AND POWER CONTACTS COME PRE-LOADED INTO INSULATORS 0.209 ± 0.012 [5.30 ± 0.30] 0.031 ± 0.012 [0.80 ± 0.30] Ø 0.026 [0.65] 0.112 [2.84] A 0.22 ± .012 [5.60 ± 0.30] Ø 0.148 [3.75] 0.059 ± 0.012 [1.50 ± 0.30] SIGNAL CONTACTS A POWER CONTACTS FRONT SEAL APPLIED BETWEEN FRONT INSULATOR AND FRONT METAL SHELL MIDDLE SEAL APPLIED BETWEEN FRONT INSULATOR AND BACK INSULATOR 1.311 ± 0.010 [33.30 ± 0.25] 0.269 [6.83] 0.269 [6.83] Ø 0.130 [3.30] 2-PLACES 0.0545 [1.38] 0.112 [2.84] DETAIL A-A SHOWN FOR REFERENCE ONLY Ø 0.043 [1.09] 5-PLACES Ø 0.165 [4.20] 2-PLACES 0.109 [2.77] TYP. RECOMMENDED PCB LAYOUT (TOLERANCE ± 0.002 [0.05]) RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = INCHES [MM] DRAWN: P. JENKINS DATE: 07/19/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 681S7W2203LYYY 3 DESCRIPTION: CLINCH NUT HARDWARE TOLERANCE: ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 0 ..... NO HARDWARE RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. 4 ..... 0.237" PCB SIDE UNITS = INCHES [MM] DRAWN: P. JENKINS DATE: 07/19/2011 ALL DIMENSIONS ARE ±0.010 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 681S7W2203LYYY 3
681S7W2203L001 价格&库存
很抱歉,暂时无法提供与“681S7W2203L001”相匹配的价格&库存,您可以联系我们找货
681S7W2203L001
  • 1+111.68633
  • 20+109.22579
  • 40+106.88676
库存:73
