DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67
ELECTRICAL:
INSULATOR RESISTANCE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
POWER CONTACT AMPERAGE:
2.089 [53.05]
1.852 [47.05]
0.492 [12.50]
A2
5
4 3
250V
-55°C TO +125°C
1.0 mΩ MAX.
SEE P/N KEY
MECHANICAL:
4.5 Kg MAX.
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE: 0.3 Kg MIN.
1.533 [38.95]
A3
5 GΩ MIN.
2
A1
1
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SHELL:
BRACKET:
BOARD LOCK:
SEAL:
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
F08 FLEXIBLE ADHESIVE
230°C PROCESS TEMP.
10 9
8 7
6
10°
0.327 [8.30]
MEETS IP67 STANDARDS
0.240
[6.10]
(SEE PAGE 3 FOR SEALING DETAILS)
0.031 [0.80]
684S13W3103LYYY
00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
P. JENKINS
DATE:
08/22/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
684S13W3103L461
2
RIGHT ANGLE BRACKET
1.852
DIMENSIONS(in/mm)
0.572
OPTION
#4-40 INSERT
0.572
Ø0.043
10-PLACES
Ø 0.165
3 PLACES
S
P
0.146
0.185
46
0.307
3.70
4.70
0.087
0.087
2.22
2.22
62
0.109
TYP.
Ø0.130
2-PLACES
0.420 [10.67]
0.0545
SIGNAL CONTACTS
0.100
0.520
POWER CONTACTS
0.370
[9.40]
PCB EDGE
Ø 0.026 [Ø 0.65]
0.420
S
Ø 0.148 [Ø 3.75]
P
0.370 [9.40]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
P. JENKINS
DATE:
08/22/2011
0.520 [13.20]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
684S13W3103L461
2
A
A
FRONT SEAL APPLIED OVER INSULATOR
AND BETWEEN FRONT & REAR SHELLS
DETAIL A-A
SHOWN FOR REFERENCE ONLY
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
P. JENKINS
DATE:
08/22/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
684S13W3103L461
2
很抱歉,暂时无法提供与“684S13W3103L461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+228.173601+29.41598
