380-009-113L001
380-009-113L001
    NORCOMP
    9 位 D 型,超微型 D 插头,公引脚 连接器, 通孔 焊接
380-009-113L001 数据手册
DESCRIPTION: MICRO D-SUB CONNECTOR - MALE SPECIFICATIONS: ELECTRICAL: INSULATOR RESISTANCE: SIGNAL CONTACT RESISTANCE: CONTACT CURRENT RATING: D.W.V.: OPERATING TEMPERATURE: 1000 MOHMS MIN. 45 mOHMS MAX. 1 AMP 500VAC -55°C TO 85°C MATERIALS: INSULATOR: PBT UL94V-0, BLK 230°C MAX PROCESS TEMP ZINC ALLOY 15u" GOLD PLATED BERYLLIUM COPPER MATING AREA TIN PLATED ON SOLDER AREA SHELL: CONTACTS: DIMENSIONS(mm) ±0.15 SIZE A B C D E 9 19.55 14.35 5.08 3.81 8.20 15 23.36 18.20 8.89 7.62 12.00 25 29.70 24.55 15.24 13.97 18.35 380-YYY-11YL001 SERIES POSITIONS 009 015 025 PCB CONTACT LENGTH 3 = 2.50mm RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: M. SIGMON DATE: 08/18/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 2 380-YYY-113L001 5 DESCRIPTION: MICRO D-SUB CONNECTOR - MALE 9 POSITION 15 POSITION CL CL HOLE SIZED DETERMINED BY FASTENER USED* 25 POSITION CL *TYPICAL RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: M. SIGMON DATE: 08/18/2011 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 2 380-YYY-113L001 5
380-009-113L001 价格&库存
很抱歉,暂时无法提供与“380-009-113L001”相匹配的价格&库存,您可以联系我们找货
380-009-113L001
    • 1+87.73658
    • 25+85.09147
    • 50+82.46718
    • 250+80.24903
    • 500+79.25972
    库存:114
    380-009-113L001
    • 1+134.522111+17.38688
    380-009-113L001
      380-009-113L001
