DESCRIPTION: POWER - VERTICAL BOARD - MALE - MACHINED
SPECIFICATIONS:
ELECTRICAL:
INSULATION RESISTANCE:
Ø 0.120
[3.05]
2-PLACES
1.543
[39.20]
DIELECTRIC WITHSTANDING VOLTAGE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
POWER PINS:
1.311
[33.30]
0.994
[25.25]
0.539
[13.70]
A2
A1
0.492
[12.50]
0.327
[8.30]
A3
5 GΩ MIN.
1000 VAC FOR 1 MIN
250V
-55°C TO +125°C
1.0 mΩ MAX.
40 AMPS
MECHANICAL:
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE:
4.5 Kg MAX.
0.3 Kg MIN.
MATERIALS:
CONTACTS:
INSULATOR:
PBT UL94V-0 RATED
SEAL:
SHELL:
HARDWARE:
F08 FLEXIBLE ADHESIVE
NICKEL PLATED STEEL
NICKEL PLATED BRASS
COPPER ALLOY, GOLD FLASH
230°C PROCESS TEMP.
10°
0.240
[6.10]
681S3W3103LYYY
0.433
[11.00]
0 = 40 AMP
0.031
[0.80]
2
3
4
5
0.963
[24.46]
1 = GOLD FLASH
SEE SHEET 2
FOR DETAILS
1.091
[27.71]
= NO HARDWARE
= 0.098" CN PCB SIDE
= 0.236" CN PCB SIDE
= 0.236" CN MATING SIDE
= 0.237" BOARDLOCK PCB SIDE
= 0.224" BOARDLOCK PCB SIDE
MEETS IP67 STANDARDS
(SEE PAGE 2 FOR SEALING DETAILS)
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
681S3W3103LYYY
3
DESCRIPTION: 681 SERIES CONTACTS
NOTE: POWER CONTACTS COME
PRE-LOADED INTO INSULATORS
0.209 ± 0.012
[5.30 ± 0.30]
0.031 ± 0.012
[0.80 ± 0.30]
A
Ø 0.148
[3.75]
0.059 ± 0.012
[1.50 ± 0.30]
A
POWER CONTACTS
FRONT SEAL APPLIED OVER INSULATOR
AND BETWEEN FRONT & REAR SHELLS
1.311 ± 0.010
[33.30 ± 0.25]
0.270
[6.85]
0.270
[6.85]
DETAIL A-A
Ø 0.130
[3.30]
2-PLACES
SHOWN FOR REFERENCE ONLY
Ø 0.166
[4.22]
3-PLACES
RECOMMENDED PCB LAYOUT
TOLERANCE ± 0.002 [0.05]
RoHS COMPLIANT
N
C
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
681S3W3103LYYY
3
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
0 ..... NO HARDWARE
2 ..... 0.236" PCB SIDE
4 ..... 0.237" PCB SIDE
1 ..... 0.098" PCB SIDE
3 ..... 0.236" MATING SIDE
5 ..... 0.224" PCB SIDE
RoHS COMPLIANT
N
C
ALL DIMENSIONS ARE ±0.010
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
681S3W3103LYYY
3
很抱歉,暂时无法提供与“681S3W3103L001”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+88.11148
- 20+86.18492
- 40+84.32084
