681M21WA4SL001
681M21WA4SL001
    NORCOMP
    CONN DSUB RCPT 21POS VERT SOLDER
681M21WA4SL001 数据手册
SPECIFICATIONS: DESCRIPTION: POWER / SIGNAL - VERTICAL - FEMALE - MACHINED ELECTRICAL: INSULATION RESISTANCE: DIELECTRIC WITHSTANDING VOLTAGE: WORKING VOLTAGE: OPERATING TEMPERATURE: POWER CONTACT RESISTANCE: SIGNAL CONTACT RESISTANCE: POWER CONTACT AMPERAGE: SIGNAL CONTACT AMPERAGE: 2.732 [69.40] 2.500 [63.50] 2.157 [54.80] Ø 0.120 2-PLACES 5 GΩ MIN. 1000 VAC FOR 1 MIN 250V -55°C TO +125°C 1.0 mΩ MAX. 10 mΩ MAX. SEE P/N KEY 5 AMPS MECHANICAL: CONTACT INSERTION FORCE: CONTACT SEPARATION FORCE: 4.5 Kg MAX. 0.3 Kg MIN. MATERIALS: CONTACTS: INSULATOR: COPPER ALLOY, GOLD FLASH PBT UL94V-0 RATED SHELL: HARDWARE: NICKEL PLATED STEEL NICKEL PLATED BRASS 230°C PROCESS TEMP. A4 A3 9 8 7 6 5 4 3 2 1 A2 A1 17 16 15 14 13 12 11 10 10° 0.311 [7.90] 0.492 [12.50] 681M21WA4SLYYY 0.228 [5.80] 0 = 40 AMP POWER // STANDARD PCB TAILS 1 = 40 AMP POWER // 2.22mm PCB TAILS 2 = 20 AMP POWER // STANDARD PCB TAILS 0.421 [10.70] 0 1 2 3 4 5 0.031 [0.80] 1 = GOLD FLASH SEE SHEET 2 FOR CONTACT DIMENSION DETAILS RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 07/19/2013 = NO HARDWARE = 0.098" CN PCB SIDE = 0.236" CN PCB SIDE = 0.236" CN MATING SIDE = 0.237" BOARDLOCK PCB SIDE = 0.224" BOARDLOCK PCB SIDE DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 3 681M21WA4SLYYY 4 DESCRIPTION: POWER / SIGNAL - VERTICAL - FEMALE - MACHINED 2.500 0.894 0.613 NOTE: SIGNAL AND POWER CONTACTS COME PRE-LOADED INTO INSULATORS 0.894 0.613 0.436 0.436 0.327 0.327 0.218 0.218 DIMENSIONS(in/mm) S P 0.218 0.177 OPTION 0.109 0&2 0.109 1 0.112 5.55 4.50 0.118 0.087 3.02 2.22 SIGNAL CONTACTS Ø 0.130 2-PLACES POWER CONTACTS 0.055 0.055 Ø 0.165 4-PLACES 0.163 0.163 0.272 0.272 0.381 Ø 0.026 [Ø 0.65] Ø 0.043 17-PLACES 0.059 [1.50] Ø 0.148 (40 AMP) [3.75] Ø 0.110 (20 AMP) [2.80] 0.112 [2.84] P 0.381 S 0.031 [0.80] RECOMMENDED PCB LAYOUT RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 07/19/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 2 3 681M21WA4SLYYY 4 DESCRIPTION: POWER / SIGNAL - VERTICAL - FEMALE - MACHINED TOLERANCE: ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS 0 ..... NO HARDWARE 2 ..... 0.236" PCB SIDE 4 ..... 0.237" PCB SIDE 1 ..... 0.098" PCB SIDE 3 ..... 0.236" MATING SIDE 5 ..... 0.224" PCB SIDE RoHS COMPLIANT N C ALL DIMENSIONS ARE ±0.010 THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = inches [mm] DRAWN: M. SIGMON DATE: 07/19/2013 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 3 3 681M21WA4SLYYY 4
681M21WA4SL001 价格&库存
很抱歉,暂时无法提供与“681M21WA4SL001”相匹配的价格&库存,您可以联系我们找货
