DESCRIPTION: POWER - RIGHT ANGLE - MALE - MACHINED - IP67
ELECTRICAL:
INSULATOR RESISTANCE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
POWER CONTACT AMPERAGE:
2.732 [69.40]
2.500 [63.50]
0.492 [12.50]
2.181 [55.40]
A1
A2
1 2
3
4 5
6
7
8
9 A3
250V
-55°C TO +125°C
1.0 mΩ MAX.
SEE P/N KEY
MECHANICAL:
4.5 Kg MAX.
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE: 0.3 Kg MIN.
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SHELL:
BRACKET:
BOARD LOCK:
SEAL:
NICKEL PLATED STEEL
NICKEL PLATED STEEL
NICKEL PLATED BRASS
F08 FLEXIBLE ADHESIVE
230°C PROCESS TEMP.
A4
10 11 12 13 14 15 16 17
0.112 [2.84]
10°
5 GΩ MIN.
0.327 [8.30]
MEETS IP67 STANDARDS
0.240 [6.10]
0.433 [11.00]
(SEE PAGE 3 FOR SEALING DETAILS)
0.031 [0.80]
684S21WA4PLYYY
00 = 40 AMP POWER // NO BRACKET // STANDARD PCB TAILS
46 = 40 AMP POWER // #4-40 BRACKET // STANDARD PCB TAILS
62 = 40 AMP POWER // #4-40 BRACKET // 2.22mm PCB TAILS
SEE SHEET 2
FOR CONTACT & BRACKET DIMENSION DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
1 = GOLD FLASH
UNITS = inches [mm]
DO NOT SCALE FROM DRAWING
DRAWN:
M. SIGMON
DATE:
06/12/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
3
684S21WA4PL461
2
RIGHT ANGLE BRACKET
DIMENSIONS(in/mm)
2.500
0.893
OPTION
#4-40 INSERT
0.618
S
P
0.146
0.185
46
0.435
0.381
3.70
4.70
0.087
0.087
2.22
2.22
62
0.326
0.272
Ø0.043
17-PLACES
0.218
0.420 [10.67]
0.163
0.109
Ø0.165
4-PLACES
0.055
SIGNAL CONTACTS
0.420
0.470
0.520
0.370
POWER CONTACTS
Ø0.130
2-PLACES
PCB EDGE
Ø 0.026 [Ø 0.65]
S
Ø 0.148 [Ø 3.75]
P
0.370 [9.40]
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
06/12/2013
0.520 [13.20]
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
3
684S21WA4PL461
2
A
A
FRONT SEAL APPLIED OVER INSULATOR
AND BETWEEN FRONT & REAR SHELLS
DETAIL A-A
SHOWN FOR REFERENCE ONLY
RoHS COMPLIANT
N
C
UNITS = inches [mm]
DRAWN:
M. SIGMON
DATE:
06/12/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
3
684S21WA4PL461
2
很抱歉,暂时无法提供与“684S21WA4PL461”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 40+209.8314740+27.05133
