DESCRIPTION: FEMALE - DIP SOLDER / MACHINED - PREMIUM
MATERIAL:
SHELL:
INSULATOR:
PROCESS TEMP.:
CONTACT:
DIMENSIONS(mm)
SIZE
A±.36
B±.10
C±.15
D±.15
E±.38
F±.25
G±.25
9
30.80
24.99
16.30
8.00
19.20
12.60
10.90
15
39.15
33.32
24.60
8.00
27.70
12.60
10.90
25
53.04
47.04
38.40
8.00
41.10
12.60
10.90
37
69.32
63.50
54.80
8.00
57.30
12.60
10.90
50
66.93
61.11
52.30
10.80
55.10
15.20
13.60
A
(2X) Ø3.05
B
0.80
C
F
PINS Ø0.60
D
G
Pin 1
5.23
5.80 (50P 6.20mm)
4.88
STEEL, TIN
UL 94V-O RATED, PA6T
260°C
BRASS (FLOATING CONTACTS)
ELECTRICAL:
CURRENT RATING: 5 AMPS
CONTACT RESISTANCE: 15 mOhms Max.
INSULATION RESISTANCE: 1,000 MOhms Min.
VOLTAGE: 500VAC FOR 1 MINUTE
TEMPERATURE: -50° C TO 100° C
172-YYY-212RYY1
SERIES
POSITIONS
009
015
025
037
050
GENDER
2 = FEMALE
TERMINATION
1 = DIP SOLDER
SHELL PLATING
2 = TIN
RoHS COMPLIANT
HARDWARE OPTIONS
00 = NO HARDWARE
01 = .065" NUT (PCB SIDE)
02 = .250" NUT (PCB SIDE)
03 = .250" NUT (MATING SIDE)
05 = .237" 4-40 BOARD LOCK
90 = .237" 4-40 BOARD LOCK
FOR 0.093" BOARD MAX.
91 = .237" 4-40 SPACER/ BOARD LOCK
92 = .237" 4-40 SPACER/ BOARD LOCK
PLATING OPTIONS
1 = GOLD FLASH
2 = 30MICRO-INCH GOLD
DO NOT SCALE FROM DRAWING
E
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OF SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
NorComp
UNITS = mm
PAM JENKINS
NTS
09-12-05
1
3
172-YYY-212RYY1
21
DESCRIPTION: PCB LAYOUT - STANDARD DSUB
1.312
CL
0.984
1.852
CL
0.656
0.378
CL
0.492
0.216
0.108
0.270
0.162
0.054
0.112 (9, 15, 25, 37 POSITON)
Ø 0.126
MINIMUM
0.326
0.218
0.109
CL
0.162
0.108
0.216
0.324
0.056 (9, 15, 25, 37 POSITON)
0.054
Ø 0.043
0.926
0.652
0.544
0.435
0.055
0.163
0.272
0.381
0.489
0.598
15 POSITION
9 POSITION
2.500
2.406
CL
CL
1.250
0.978
0.870
0.761
0.652
0.544
0.435
0.326
0.218
0.109
25 POSITION
1.203
0.870
0.761
0.652
0.544
0.435
0.326
0.218
0.109
0.224
CL
0.055
0.163
0.272
0.381
0.489
0.598
0.707
0.815
0.924
37 POSITION
0.055
0.163
0.272
0.381
0.489
0.598
0.707
0.815
50 POSITION
N
C
0.112
UNITS = inch
TYP.
SUGGESTED SIZE
MAY NOT BE SUITABLE FOR ALL APPLICATIONS
NorComp
PAM JENKINS
NTS
09-12-05
2
3
172-YYY-212RYY1
21
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL DIMENSIONS ARE ±0.010
UNLESS OTHERWISE
SPECIFIED
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
**NOTE: 90 & 92 OPTION FOR 0.093" MAX. BOARD THICKNESS
"02" // PCB SIDE
"01" // PCB SIDE
"03" // MATING SIDE
0.293
0.293
0.108
0.065
0.250
0.250
"91" // PCB SIDE
"05" // PCB SIDE
"90" // PCB SIDE **
0.234 REF ONLY
0.506 +0.000
-0.030
0.280 +0.005
-0.025
0.280 +0.005
-0.025
0.237 REF ONLY
0.237 REF ONLY
0.237 REF ONLY
NOTE: 4-40 FEMALE SCREW LOCK IS REMOVABLE
"92" // PCB SIDE **
0.234 REF ONLY
0.506 +0.000
-0.030
UNITS = inch
N
C
0.237 REF ONLY
RoHS COMPLIANT
NorComp
PAM JENKINS
NTS
09-12-05
3
3
172-YYY-212RYY1
21
很抱歉,暂时无法提供与“172-037-212R031”相匹配的价格&库存,您可以联系我们找货
