DESCRIPTION: POWER / SIGNAL - VERTICAL BOARD - FEMALE
SPECIFICATIONS:
ELECTRICAL:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
SIGNAL CONTACT RESISTANCE:
POWER PINS:
SIGNAL PINS:
2.089 [53.05]
±0.010 [±0.25]
1.852 [47.05]
±0.010 [±0.25]
1.512 [38.40]
±0.010 [±0.25]
A1
1 2 3
6 7
0.112
[2.84]
4 5
Ø 0.120 [Ø3.05]
2-PLACES
A3
A2
0.492 [12.50]
±0.010 [±0.25]
8 9 10
10°
SEE SHEET 2 FOR
PIN DIMENSIONS
250V
-55°C TO +125°C
1.0 mΩ MAX.
10 mΩ MAX.
40 AMPS
5 AMPS
MECHANICAL:
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE:
4.5 Kg MAX.
0.3 Kg MIN.
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SEAL:
SHELL:
HARDWARE:
F08 FLEXIBLE ADHESIVE
NICKEL PLATED STEEL
NICKEL PLATED BRASS
230°C PROCESS TEMP.
0.311 [7.90]
±0.010 [±0.25]
681S13W3203LYYY
0.228 [5.80]
0.421 [10.70]
5 GΩ MIN.
1000 VAC FOR 1 MIN
0 = 40 AMP
0.031 [0.80]
±0.008 [±0.20]
0 = NO HARDWARE
4 = 0.237" BOARDLOCK PCB SIDE
1 = GOLD FLASH
SEE SHEET 2
FOR DETAILS
MEETS IP67 STANDARDS
(SEE PAGE 2 FOR SEALING DETAILS)
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
4
681S13W3203LYYY
2
DESCRIPTION: 681 SERIES CONTACTS
NOTE: SIGNAL AND POWER CONTACTS
COME PRE-LOADED INTO INSULATORS
Ø 0.026
[0.65]
0.112
[2.84]
A
0.22 ± .012
[5.60 ± 0.30]
SIGNAL CONTACTS
A
FRONT SEAL APPLIED BETWEEN
FRONT INSULATOR AND
FRONT METAL SHELL
MIDDLE SEAL APPLIED BETWEEN
FRONT INSULATOR AND
BACK INSULATOR
0.209 ± 0.012
[5.30 ± 0.30]
0.031 ± 0.012
[0.80 ± 0.30]
DETAIL A-A
SHOWN FOR REFERENCE ONLY
Ø 0.148
[3.75]
0.059 ± 0.012
[1.50 ± 0.30]
POWER CONTACTS
RoHS COMPLIANT
N
C
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
4
681S13W3203LYYY
2
DESCRIPTION: PCB LAYOUT
1.852 ± 0.010
[47.05 ± 0.25]
0.570
[14.48]
0.570
[14.48]
0.306
0.326
[8.28]
0.218
[5.54]
Ø 0.130
[3.30]
2-PLACES
0.109
[2.77]
0.109
[2.77]
Ø 0.043
[1.09]
10-PLACES
0.112
[2.84]
0.0545
[1.38]
0.0545
[1.38]
0.163
[4.14]
Ø 0.166
[4.22]
3-PLACES
0.272
[6.91]
0.381
[9.68]
RECOMMENDED PCB LAYOUT
TOLERANCE ± 0.002 [0.05]
RoHS COMPLIANT
N
C
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
4
681S13W3203LYYY
2
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
0 ..... NO HARDWARE
RoHS COMPLIANT
N
C
4 ..... 0.237" PCB SIDE
UNITS = INCHES [MM]
DRAWN:
P. JENKINS
DATE:
09/13/2011
ALL DIMENSIONS ARE ±0.010
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
4
4
681S13W3203LYYY
2
很抱歉,暂时无法提供与“681S13W3203L001”相匹配的价格&库存,您可以联系我们找货
